Thread: How do i dilute fas dpd for fc test?
    Do i fill the container with 5 ml of pool water and the other 5 with tap water that is well balanced with a ph of 7.5 and alc of 90.
    If i understand it right i would just have to count each drop as 1 ppm.
    Thanks
    Ps i have high fc right now and i dont want to waste all my products.
    42,000 liters inground pool
    swg aqua rite
    Hayward super filter sand
    Vinyl lining
    Haward 1.5 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How do i dilute fas dpd for fc test?
    Don't use tap water unless it is unchlorinated well water. Just mix together equal parts (cups, shot glasses, tablespoons or whatever) of pool water and unchlorinated water. Then fill the sample tube with the mixture.
    distilled water is unchlorinated.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
