Thread: Inground Pool Repair Advice :?
    Hi,
    I am a new member. I am looking for advice regarding pool repair. We live in NE and had our inground 16x32 vinyl liner pool installed 10 yrs. ago. One contractor installed the pool and a second contractor installed the concrete decking. Two hairline cracks appeared after the first winter. We called both contractors who said this was common and we must have expansion or ice dam problems. The hairline cracks have become larger and the coping is now becoming a problem. The cracks have caused 2 tears in the liner (above the water line). I have a few questions: What should we do? Is it repairable? We live in NE - shouldn't the structure of the pool have compensated for the NE winters? Could this have been a bad install?
    Any advice is appreciated!
    MEL
    South Central NJ
    3,192
    Re: Inground Pool Repair Advice :?
    Not all liner pools are constructed the same. No two properties are the same. The number of variables is quite substantial.
    Some pictures would help.
    Often, the underlying cause is hidden until the time to repair comes and things become exposed. Pointing fingers won't do anything but raise tension. I think the goal is to fix the pool, not aggravate the bummer of a situation by spreading the "cheer", if you know what I mean.
    Scott
    Owner of - PoolGuyNJ LLC
    Hi Scott,
    It is a bummer and I'm not trying to find fault. I am confused as to "where to start". I will take a few pictures if that helps.
    MEL
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Hi, once you post some pics and we can go from their
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Hi,
    I realize this took a while but I finally was able to get pictures of my pool! It was difficult to get the pics so small - I hope you can see the problem. If you have any advice - I sure need it! As I mentioned, this pool is only 10 yrs old and the cracks appeared in year 1.
    Thanks!
