Results 1 to 7 of 7
Thread: Talcum Powder
    Jul 2009
    Mission Viejo, CA
    26
    Talcum Powder
    Hello all,
    It is pool season again and I am back. It is decided that we're only going to have the pool up July-September every year since that is when people would be using it, and we don't really feel like having to care for a pool we're not using the other 9 months.
    Anyway, when I packaged up my pool at the end of the season last year, it said to use talcum/baby powder on the liner to keep it dry while in storage. So this year when I set it up, I did not think it was necessary to wash out the talcum power before filling it because I figured the pump filter and chemicals would clean it out. However this does not seem to be the case; the water will be clear after running the pump for the 4.5 hours, but as soon as people are swimming the water becomes cloudy again which I suspect is the talcum power getting stirred up from the bottom. The pool has been up for 2 weeks at this point.
    Any suggestions for filtering out whatever is causing the water to become cloudy? Do they make finer filters for the pump I have?
    12'x36" Metal Frame Intex AG Pool - 2119.5 Gallons
    GAME 4510 1/2 HP Pump & Sand Filter w/ ZeoSand
    Re: Talcum Powder
    That doesn't sound like it has anything to do with the talcum powder. You should post a full set of water test results. It is probably something to do with your chemical levels.
    30,421
    Re: Talcum Powder
    Posting a full set of test results is about the only way to keep from simply guessing at the problem. If you are positive that is the cause, continued filtration is the only way I can think to remove it.
    Jul 2009
    Mission Viejo, CA
    26
    Re: Talcum Powder
    test results are fine...the water is newish < 3 weeks
    Re: Talcum Powder
    "Fine" doesn't tell us anything. Everyone has a different definition of what "fine" is, and we have no way of guessing what yours is. If you post a full set of test results it is very likely we will see something in the numbers that can help your problem.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Talcum Powder
    .......NEW................doesn't mean anything either!
    Re: Talcum Powder
    i have the same problem with the talcum powder and i assume you will need to vaccumn it out as soon as you get pool up (before you add salt if using a salt water system) it seems to go through alot of filters with my pool. it has been 2 months and still getting it out. i am gone alot so it is hard for me to get it out without help from others. if you will use panty hose on the end of your vaccumn it will hold the small particles and get it out along with sand. hope this helps
    Bullzak_83 (aka Trey)
    Arl, Texas
    16'X48" Intex Metal Frame
    W/Intex sand filter and Chlorine generator
