Thread: Pool Builder has no idea what the flow rate on filter is...?
    Jun 2010
    San Antonio, Texas
    23
    Hey Everyone
    Just talked with the pool builder and they have no idea what the flow rate is for the filter. They did tell me that if my chems were correct and I was keeping the pool clean that running the filter 4-5 hrs will clean the water (depending on bather load).
    Note: This pool is 10 years old.
    Also, I am having trouble with the rear Weir door ocassionally sticking. It's hanging on a piece of metal/plastic on the topside that has bowed in the middle and is chipped so that the jagged edges hang the door up. This happens mostly when the pool is overfilled a bit from either rain or water being added.
    Can the pool wizards tell me what repairs will need to be done?
    Thank you
    24,268 gal/DE/IG Plaster
    Pentair 320 Auto In-Line Chlorine/Bromine Filter, Century Magnatec 2 spd. motor, PB4 Booster Pump, Purex Triton Whisperflo Pump, Polaris 380 Pool Cleaner
    30,419
    Re: Pool Builder has no idea what the flow rate on filter is...?
    You should be able to go the manufacturer's website and get help on your flow rate for the filter.
    I cannot picture what you're describing about the weir so I am no help.
    22,548
    Are you saying that the piece above the weir is bowed down?
    Maybe a little trimming or heating it and bowing it back up might work.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,595
    If it's plastic----------sand it............If it's metal.........grind or trim it. go...........S.....L.......O......W!
    Jun 2010
    San Antonio, Texas
    23
    Yes, the piece above the Weir door is bowing and has chipped - it looks like a flat piece of sheet metal but it isn't metal - it's rigid like a flat piece of PVC (I hope I make sense here). I noticed it when I was trying to figure out why the filter was increasing in psi shortly after backwashing and I needed to bump it way too much - then the Polaris acted up - even though it was blowing water it wasn't moving. I thought I was losing my mind until my son mentioned the sticky Weir door. It sticks when the water is at the correct level or higher. A great deal of heat then builds up in there until the door is knocked down. Obviously the filter takes in air...and so on.
    I appreciate the comments so much. This is bigger than me and I don't feel qualified to do this repair so I called the builder to come out Friday and tell me what they would do. I'll post back after July 9th.
    BTW: My pool is beautiful - it shimmers, it's so clean, it feels great and my family loves me (well they'd love me even if it was full of slime but they do favors for me now...lol) thanks to the water wizards at TFP I am no longer a LPS addict.
    Jun 2010
    San Antonio, Texas
    23
    Follow up to stuck Weir door
    Pool builder/service guy stops by and ends up hacksawing a black horizontal polypropylene sheet (about 1/8 inch thick) out of the area above the Weir door! He tells me it was left in there from the construction of the pool (10 years ago). there is now a strong current around the pool from skimmer to skimmer that was never there before. Wow - what a difference that made - I am able to cut down on the the daily run time of the filter by a couple hours and the pool looks even cleaner. Who knew?
    Again I asked this service guy to tell me what the flow rate was because I can't find any reference to it on the equipment - he says he doesn't know either.
