Results 1 to 8 of 8
Thread: How much does chlorine loss in pool party
    Jun 2010
    NW Foothills of North Carolina
    21
    I imagine that chlorine will drop during a pool party, but does this look normal?
    7/5
    10am - FC = 15
    2pm - 7pm - Pool Party
    7:30pm - FC = 6.5 (is this a normal chlorine loss for a party?)
    Added bleach to FC = 7 (tested) before bed.
    7/6
    9am - FC = 7 (no algae)
    12pm - 1pm - (only person in pool was my sister and her dog. Just in pool to cool off while sunbathing)
    1pm - FC = 4.5 (2.5 in 4 hours)
    Added 1 gallon, 3 cups bleach to FC = 8 (did not test)
    6pm - 8pm - Pool Party
    8pm - FC = 6
    added 2 quarts, 3 cups bleach to FC = 8 (did not test)
    The CYA = 40-50 (closer to the 40 line)
    pH = 7.5
    TA = 90
    CYA = 110
    CC = 0.5
    21K gallon, 16 x32 IG Vinyl, 3/4 HP Hayward Superpump,
    200 lbs Sand filter, Full sun all day
    30,414
    Re: How much does chlorine loss in pool party
    A heavy swimmer load reduces chlorine. You don't say how big your party was but I would say those numbers look typical.
    How does your water look?
    Jun 2010
    21
    The party usually consist of about ~10 -15. Most are children or teenagers.
    I figured that parties would consume a lot of chlorine, but did not know how much.
    So losing 2.5 in about 4 hours is normal. I was thinking that it would be about 3 a day.
    Regardless, the pool is more clear than it has been in two years.
    Thanks!
    Jul 2009
    Monterrey, MX
    37
    I've made some calculations for my pool from information found here in deep end and the result is 0.16 ppm FC per hour per bather for a 6.8k gallon pool. I've not verified it (my pool is not ready to be filled yet). With this number I calculate 2.69 ppm of FC for 13 bather, 4 hours for 21k pool.
    10' x 20' x 52" In Ground Pool 6,600 gallons, 2" piping, TFTestkit
    24" Sand filter / Espa Silen 0.8 hp pump
    And much more for a dog! (more dirt, more hair, more body oils)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    FC loss can range from 2-6ppm. If someone did not obey the no pee in the pool rule, it could certainly be more and the Dog can carry a lot of "organic" matter on their coat
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by gumarogarc
    It looks like my very rough estimate of every person-hour in a pool consuming around 3 ppm FC in 350 gallons (0.105 ppm in 10,000 gallons) described in this post underestimated this particular situation. 13 bathers for 5 hours (1st party) in 21,000 gallons would be around 3.25 ppm FC. However, the actual loss was from 15 to 6.5 ppm so 8.5 ppm, though some of this was loss due to sunlight. The bather load loss was probably at least 7 ppm. So it may be that one or more of the people in the party urinated in the pool (or the assumptions used for the calculations are wrong). As for the loss of 2.5 ppm FC in 4 hours with one person and a dog -- well, if a dog carries in a lot of organics in their coat then that could create a lot of chlorine demand (and some of this was loss from sunlight). 13 bathers for 2 hours (2nd party) in 21,000 gallons would be around 1.3 ppm FC compared to the actual drop of 2 ppm.
    Jun 2010
    21
    Thanks for all of the info. I guess I'm make people take bathroom breaks, whether they need it of not. Or maybe I'll ask for donations of bleach.
    "Welcome to our ool. There is no p it. Let's keep it this way!"
