Thread: Back from vacation: pool disaster
    Just got back after 10 days to find what every pool owner hopes to never see: cloudy, green mess. There are several issues going on. First...the pump has developed a leak to where it's losing probably a couple inches (or more) per day--it's hard to say for sure because it's been raining yesterday and today. The neighbor watching the pool let the water level drop below the skimmer sometime on Saturday, so basically no circulation for about 72 hours. Amazingly, the pump didn't burn up and still works (with a leak, of course). Parts for the pump are in and should be repaired by tomorrow (hopefully). Second, ducks have decided to treat themselves to nightly swims in our pool (or more correctly, their 23,000 gallon toilet). As I began to clear up the water yesterday by shocking with 12.5% CL, I watched the CL go from 30 ppm to 0 overnight. Took it back up to shock level today and again...within hours back to 0. Finally I wised up and checked the cya and there was none. The last cya test I'd done was back in May when it had it at 60 ppm for the SWG. There's been significant water loss, but certainly not enough to lose 60 ppm. I just ran an amonia test (with a test kit from my aquarium) and it reads 0. To make a bad situation worse...take a look at these pictures (taken while it was raining earlier this evening):
    Obviously something got into the water to make it foam like that.
    I am making progress. I can see the drains in the deep end and the pool is starting to hold chlorine, but it's still fighting something. I lost 6 ppm in the last hour after the sun went down. We'll see how much is left in the morning.
    Here's a quick summary:
    -pump is leaking
    -water lost all CL & cya
    -ducks are pooping in pool
    -water was cloudy and green; now clearing but still green with some kind of foam
    -wife is pi55ed off
    Other than that, everything's GREAT!
    Here's my numbers:
    FC 20 ppm
    CC 1 ppm
    ph 7.3
    cya 0
    alk 170
    salt 3500
    Any ideas? I need to get stabilizer back into the water, but where should my target be for cya and cl while I'm clearing this up? Did the non-priming pump contribute to any of this?
    23K IG vinyl, Autopilot SWG, 1 HP Aqua-Flo Dominator Pump, 30" Cooper Ranger series sand filter, 1 skimmer, 3 jets, 2 fountains, 2 main drains.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Back from vacation: pool disaster
    With CYA 0, during the day you're losing nearly all FC to sunlight before it can do any good. You want 20-30ppm asap. After you clear the pool and hold FC overnight, you can bring it back up to normal SWG levels.
    No clue about the foam but it's probably worthwhile trying to skim it off.
    --paulr
    BBB "Intermediate Swimmer"
    What PaulR said, get some CYA in there ASAP. Aiming for a CYA of 30 is a good place to start, then raise it further once the water clears up. Other than that, you are on the right track. Chlorine will clean up the foam, though it may take a couple of days.
    Quick update:
    the pool lost 9 ppm overnight (about 45% of the FC) the foam is gone and the water is getting pretty clear. CC's are down to .5 and the FC is at 8ppm. I am currently dissolving the first 5 pounds of cya to see where that gets me. I'd like to know what caused the cya to drop to 0. I thought I read in another thread that bacteria in the water can eat up the cya. Is there some other test I should run for bacteria? Is the course of action the same: hold the water at shock level until there's no FC loss overnight?
    Now that I can see the bottom, I noticed a green hue in the water and brownish staining on the liner and returns:
    I rubbed a vitamin c tablet on one of the returns and it whitened up nicely. But how do I remove the stains from the entire pool?
    Thanks for your help,
    Bill
    There is a kind of bacteria that can break down CYA. It can only grow when the FC level is zero, and dies the instant there is any chlorine in the water.
    You should add a startup dose of sequestrant and lower the PH down to around 7.2 (when the FC level is relatively low) to help with the stains. There is some chance that will clean things up. If the stains still remain when you have things back to normal you can do an AA treatment to remove the stains everywhere.
