Need help installing sand filter
Jul 13, 2008
18
I bought a used sand filter off Craigslist. I don't know the brand and there are no readable markings. Can anyone give me a clue as to which port is which? (i.e. can you tell by which side the pressure gauge is etc?) I'll be hooking this up to a 3/4 hp pump and 12000 gallon above ground pool. From what I understand the hose from the pool goes to the pump, from pump to intake on filter, and output of filter goes back to pool, and the 3rd port is for flushing/waste.
Any hints etc are greatly appreciated. Also if anyone has any generic instructions for using a sand filter and what to do the first time you run it, flush it etc.
Here are some pics.
It's a Sand Dollar Looks like a SD-60 or maybe an SD-80.
Here's how it's plumbed. In the picture with the white pipe to the top.
The white pipe is the waste port.
The port to Right (opposite pressure gauge) is the inlet from the pump discharge.
The Bottom port (opposite the white pipe) is the outlet port that returns back to the pool.
You can probably call Pentair and they may sell you a new top label. I can give you the positions this evening when I get home if you need them.
Fill with sand till the top of the sand bed is ~12" from the neck. Sand comes in 50 LB bags. Cover the center pipe and keep it centered when pouring the sand. Don't sweat a little spillage. Don't buy wet sand. It doesn't flow from the bag when pouring, a significant PITA.
Model Tank diameter Lbs. of Sand
SD35 16.5" 100
SD40 19.5" 150
SD60 22.5" 250
SD70 24 300
SD80 26 350
Scott
Welcome to TFP!!
I strongly! suggest to replace the first 1/4 of sand with pea gravel (1/8 - 1/4")
Fill the tank 1/2 way with water before adding the pea gravel or sand, to reduce the impact on the laterals, cover the stand pipe, as per Scott, and add slowly :)
Please make sure that the laterals and stand pipe are in good shape before refilling the filter!
There are a couple reasons I can name, and probably other benefits I can't :)
The pea gravel around the laterals improves the flow & sand will become embedded in the laterals at some point and restrict the flow, et. al.
If a lateral breaks, you won't get sand flowing back into the pool :-D
There have been a couple of discussions about this but my search term is too broad to find them :rant: (I'm not very good with the computer :oops: )
Old time filter set-ups layered decent sized rocks on to perforated pipes on the bottom followed by smaller stones down to pea gravel before the sand. I vaguely remember the original filter on our 1946 pool being of boilerplate steel and standing four feet high and maybe 40" across. We had two for a 40,000 gallon pool. Loaded, each must have weighed at least a thousand pounds. Anyway, besides showing my age, I just wanted to point out the gravel/sand interface is an ancient technique in pool filtration.
