Results 1 to 13 of 13
Thread: Need help installing sand filter
    I bought a used sand filter off Craigslist. I don't know the brand and there are no readable markings. Can anyone give me a clue as to which port is which? (i.e. can you tell by which side the pressure gauge is etc?) I'll be hooking this up to a 3/4 hp pump and 12000 gallon above ground pool. From what I understand the hose from the pool goes to the pump, from pump to intake on filter, and output of filter goes back to pool, and the 3rd port is for flushing/waste.
    Any hints etc are greatly appreciated. Also if anyone has any generic instructions for using a sand filter and what to do the first time you run it, flush it etc.
    Here are some pics.
    South Central NJ
    3,192
    Re: Need help installing sand filter
    It a Pentair Sand Dollar, though I can't discern which size.
    Scott
    Owner of - PoolGuyNJ LLC
    22,553
    It's a Sand Dollar Looks like a SD-60 or maybe an SD-80.
    Here's how it's plumbed. In the picture with the white pipe to the top.
    The white pipe is the waste port.
    The port to Right (opposite pressure gauge) is the inlet from the pump discharge.
    The Bottom port (opposite the white pipe) is the outlet port that returns back to the pool.
    You can probably call Pentair and they may sell you a new top label. I can give you the positions this evening when I get home if you need them.
    Thanks! Found documentation online from Pentair, will install it this weekend.
    Ok, one more question...how do I know how much sand to put in it?
    South Central NJ
    3,192
    Fill with sand till the top of the sand bed is ~12" from the neck. Sand comes in 50 LB bags. Cover the center pipe and keep it centered when pouring the sand. Don't sweat a little spillage. Don't buy wet sand. It doesn't flow from the bag when pouring, a significant PITA.
    Model Tank diameter Lbs. of Sand
    SD35 16.5" 100
    SD40 19.5" 150
    SD60 22.5" 250
    SD70 24 300
    SD80 26 350
    Scott
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I strongly! suggest to replace the first 1/4 of sand with pea gravel (1/8 - 1/4")
    Fill the tank 1/2 way with water before adding the pea gravel or sand, to reduce the impact on the laterals, cover the stand pipe, as per Scott, and add slowly
    Please make sure that the laterals and stand pipe are in good shape before refilling the filter!
    Luv& Luk
    -Ted
    Jun 2010
    Toms River, NJ
    80
    This is the first I've heard of the gravel trick. Can you please explain what the purpose is?
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    Mar 2007
    4,160
    There are a couple reasons I can name, and probably other benefits I can't
    The pea gravel around the laterals improves the flow & sand will become embedded in the laterals at some point and restrict the flow, et. al.
    If a lateral breaks, you won't get sand flowing back into the pool
    There have been a couple of discussions about this but my search term is too broad to find them (I'm not very good with the computer )
    Luv& Luk
    -Ted
    Where can you typically get sand for the filter, and which type? Will the sandbox sand at Lowes work?
    Jun 2010
    Toms River, NJ
    80
    no, it is a special sand designed specifically for filters. You can get it at a local pool store. You can also check your lowes by the pool stuff they sometimes carry it.
    22,553
    It needs to be #20/21 filter sand. Lowes sometimes carry it.
    Jun 2007
    New Jersey
    653
    Old time filter set-ups layered decent sized rocks on to perforated pipes on the bottom followed by smaller stones down to pea gravel before the sand. I vaguely remember the original filter on our 1946 pool being of boilerplate steel and standing four feet high and maybe 40" across. We had two for a 40,000 gallon pool. Loaded, each must have weighed at least a thousand pounds. Anyway, besides showing my age, I just wanted to point out the gravel/sand interface is an ancient technique in pool filtration.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
