Results 1 to 7 of 7
Thread: Cloudy water
    Jun 2007
    MA
    165
    Cloudy water
    It was VERY hot/humid I think we had 10 people in pool from 9am to 8ish, water is now cloudy. PH and FC look fine. Should I just let pump run all night to clear it up?
    Cheryl
    14X42 Intex Ultra Frame
    30,431
    Re: Cloudy water
    What are your current test results for FC? What was your last CYA test result?
    Jun 2007
    MA
    165
    Re: Cloudy water
    fc 5
    cya 40
    Cheryl
    30,431
    Re: Cloudy water
    Yes, with those numbers, simply running the pump should clear the pool. Keep the FC around 5ppm while it's clearing......it may take a while.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Re: Cloudy water
    Quote Originally Posted by my4boys2002
    I noticed after having a day full of kids in my pool (15x36 intex) my water was very cloudy. I ran the pump for 3-4 hours and no change.
    Took the filter out and used my hose to spray all the junk off it and put it back in.
    My pool was clear in about 2 hours. From what Ive read online you can pull the filter and rinse it ever 2-5 days depending on traffic in the pool. It beats replacing it every 2 weeks like they recommend in the manual.
    Also where something to protect your eyes while spraying the filter you dont want to get any leftover chemicals that are stuck to the filter in you eyes.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    Re: Cloudy water
    The Intex paper filters wear out quite quickly when you try and clean them. You can get much sturdier third party filter cartridges that can be cleaned and reused for several years for not to much more than an Intex three pack.
    Jun 2007
    MA
    165
    Re: Cloudy water
    I use rinz n reuz it's made of plastic and some kind of fabric, I usually clean it every other day
    Cheryl
