Results 1 to 12 of 12
Thread: Small Pool Pictures ?
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    My yard is pretty small and I'm looking into buying a 12' x 24' kidney shaped pool. I'm a bit worried about the size and would like to see a few pictures to get a better idea of what it's going to look like.
    Any picture, links or comments would be appreciated.
    Thanks.
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    ktdave's Avatar
    Katy, TX
    888
    I don't have a kidney shaped pool, but I do have what I consider a small yard. My yard is 28 ft from back of house to fence and about 60 ft wide. I do have a corner cut-out of the house that helped us with space for the deep end of the pool. The pool is 34 ft long and 8 ft wide shallow end and as wide as 17 ft in the deep end.
    We used up all the space that wasn't in a utility easement. One day I'll get around to landscaping.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    When I saw the question I though about KTDave's pool.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by tagprod
    Easy now ! You're gonna give me a pool envy complex!
    Pool School
    TF Test Kits
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Nice pool, thanks for the picture
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Quote Originally Posted by ktdave
    I thought you did a good job with the sized yard you had to work with. I meant it in the most respectful manner possible.
    Brian
    ktdave's Avatar
    Katy, TX
    888
    Oh, I was just kiddin! No offense taken.
    Pool School
    TF Test Kits
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    Dave...I too thought of the way you used your space....you should feel so special to have so many people thinking about you!
    el_steak....anything is possible these days. I assume you will be doing an in ground pool???? If you choose the right builder as KTDave did, they can custom design that pool specifically for your space and conform to any building easments etc... Good luck....keep everyone in the loop as you move forward.
    Jay
    36' x19' Freeform, 16' waterfall w/ groto and slide, 5' x 10' sundeck, 12" raised spa. Pentair IntelliTouch, Pentair IntelliFlo 4 x 160, Master Temp 400, IntelliChlor Chlorine generator, Aqua Blue PebbleSheen
    New Brunswick Canada
    819
    Small Backyard
    Here is a pic of our pool. Its 14 X 28 Key Shaped, as you can see, our backyard was rather tight. I would suggest you find a shape you like, then buy a can of spray paint, and draw it in, see if it fits with your ideas.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Re: Small Backyard
    Quote Originally Posted by pooladdict
    A Garden hose will do wonders as well to layout your area.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Check out Waterbear's pictures Waterbear's pool
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Thanks for the pic. 14x 28 seems like a decent size. I'm a bit concerned that 12' x 24' will be too small for our enjoyment. I'll see if It makes sense to squeeze in a 15x26' instead...
    I'm testing the layout the virtual way with software (SketchUp), but I guess there's nothing like having it for real in your own backyard.
