Results 1 to 11 of 11
Thread: First time cleaning filter questions
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    We think it is time to clean the filter but, with our simple set-up I don't see any shut off valves and the filter is lower than the pool return and skimmer. How do we keep the water from draining out while we clean the filter? Being the first time, I'm sure it will take us longer than most people.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: First time cleaning filter questions
    That's an interesting question------wish I had an interesting answer! If worse comes to worse, you can always drain it to the bottom of the skimmer and stick a "cork" of some kind or a screw in plug in the return eyeball I guess. Please somebody give us a better answer!
    Feb 2008
    Denton, TX
    5,061
    I was thinking along those lines, sort of. I was actually wondering if some threaded PVC plugs could be found to plug the returns and skimmer drains temporarily.
    Jun 2007
    New Jersey
    653
    If you have flexible hoses, you can just pull them off the pump/filter and tie them to the pool wall with the ends above the water line. You lose a few gallons going back and forth but it works.
    Long-term, you would want to get threaded plugs or rubber expansion plugs for convenience.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Quote Originally Posted by Durk
    This sounds feasible. We have flexible hose connected to pvc pipe that runs to the pump and filter.
    Aug 2008
    Conway SC
    102
    First off, buy a Plug at the pool store.. Around $3.00. For the Skimmer, buy a skimmer plate (Dont know the actually name for it). Its a plate with a rubber gasket that goes in front of the skimmer for the winter time..
    After you plug it, install the shut off valves but there are some cheap ones out there (Even though there expensive in price) that are useless and the handles break. I got my valves at HD.
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    I would replace the flexible hose coming off the pool with hard PVC and put valves on them. It seems strange that there is pvc in ground and hose on top!
    Love TFP? Become a
    TFP Supporter!
    Aug 2008
    Conway SC
    102
    Question.. Who wired that.. LOL..
    Sand Filter
    City Water.
    Mar 2007
    Coastalish 'down easter'
    4,160
    As said, 2 SP 1022-C 1.5" winterizing plugs will seal the return and the skimmer (save the Aquadoor for the fall when you winterize - you need to drain the water below the skimmer and replace the faceplate to install one )
    Have fun cleaning the filter, don't get too wet
    Luv& Luk
    -Ted
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Thanks for all the advice. Cleaned the filter today and other than a little water everywhere, it went well! We definitely will be redoing the plumbing and adding some shut off valves.
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Quote Originally Posted by Sparkmaster
    That would be my DH. He had to run the wiring in a hurry for the installers and then never finished. I asked if we should turn everything off when getting in the water!!! He didn't laugh!
