Thread: Recycled water implications
    My new intex pool gets a fair amount of spray from 3 of my sprinkler heads. Is this something I need to worry about? I've been looking at how to adjust them although I don't have the tool to do it yet. Saddly I've done a fair amount of searching and I only find warnings not to full your entire pool using recycled water.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Recycled water implications
    Isn't all water recycled in some form or another?
    Are these sprinkler fed from a gray water tank? If it is the same as your tap water there is no problem.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Feb 2008
    Denton, TX
    5,061
    No, I wouldn't really worry about it. It's just going to top your pool off when they run. If they are adding enough water to really raise the level, then you should do as you intended and just adjust the spray head pattern. Keep in mind that if they are adding a significant amount of water, this can dilute your chemicals so you may find that you need to add more.
    ETA: Agree absolutely with svenpup. Typing at the same time.
    no tanks, fl water supply. this is a large scale system of distributing water to the whole neighborhood for personal sprinkler system use. It does seem to add abit of water to it as I found tonight taking a dip into it.
