Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: STILL -More than Halfway there
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Great site - wish I'd surfed here MUCH earlier in the process.
    Our pool was "shot" on Friday and plumbed today so much of the pre-handwringing is over. Nevertheless, I'd thought I'd offer a photo of the newly shot pool with our specs. We decided to build a basic pool with no bells & whistles. Chosing the builder has tough - especially in NE FL as there are many. It came down to experience and confidence that I would get a solid pool. The company has been for more than 32 yrs. I also leaned towards the wet-mix shotcrete rather than gunite.
    - 30' x 15' kidney wet-mix shotcrete inground
    - 3.5 to 5.5' deep
    - 36" main drain
    - 1 skimmer; 4 returns
    - normal light
    - 2 seating shelves
    - step-up for elevation/drainage
    - Dyna-Pro single speed 1 HP pump
    - Sta-Rite 2 filter - PLM100
    - AutoPilot Digital SWG - RC35/22 cell
    - Polaris 360 cleaner (vacuum return not needed)
    - Concrete pavers (slightly slate textured)
    - Marbletite (Marquis series - Bluestone finish)
    - screen enclosure
    Next step - the electrican. Wish I'd thought to include an additional outlet inside the enclosure area now that I think about it!
    Cheers - Taz
    edit: to change the title
    30' x 15' kidney shaped, 3.5-5.5 ft deep, wet-mix shotcrete inground, AutoPilot Digital SWG - RC35/22 cell, 36" main drain, 1 skimmer, 4 returns, Dyna-Pro 1 HP, Sta-Rite 2 (PLM100) filter, Polaris 360 cleaner, Marbletite (Marquis/Bluestone), Screen enclosure
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Halfway there
    Looking good! Keep the pictures coming!
    Guest
    Re: Halfway there
    Looks great
    See if they will upgrade you to the PLM150 filter, and ask them about a 2 speed pump as well. If they won't budge on the pump, I would suggest going down to a 3/4 HP pump. Your pool does not have enough water to warrant a 1 HP pump, and you will save money and sacrifice nothing as far as function by using the 3/4 HP pump.
    Keep the pics coming!
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Re: Halfway there
    Quote Originally Posted by simicrintz
    Looks great
    Didn't think of the 2 speed pump (& my wife is an environmental engineer). I'm leaning towards keeping the 1 HP pump as we will likely add solar w/in a year & need the additional capacity. A 3/4 HP pump wouldn't handle the additional head needed. Everything is wired in - the tiles should be done Monday or Tuesday. Regretfully, my irrigation revamp & resod will more than eat my budget.
    Feb 2008
    Denton, TX
    5,061
    Re: Halfway there
    Looks good! I would consider the two-speed pump as well FWIW.
    Guest
    Re: Halfway there
    Check your head curve on the pump before you make the final decision. I've plumbed in many pools with solar on 3/4 HP pumps (StaRite, by the way, which it appears you are using/getting) with no problem.
    More horsepower is great for race cars and lawn mowers, but not so much for swimming pool pumps. Slower water moving through filtration, combined with bigger pipes make for efficient pools. Using the assumption that you will have approx. 15,000 gallons of water in your pool (based on your dimensions), you will need a pump that pushes about 42 gpm. That is about half of what the 1 HP will do, so you will (in essence) be trying to move twice as much water through your system with the 1 HP pump. Unless you have a very high house, and a very long run (with very small pipe and lots of 90's), I think you will find that the head on the 3/4 HP pump will work just fine.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Halfway there
    Love me a kidney shaped pool. Small, and simple! Less water, less chemicals, more $$ in your pocket. Smart man!
    like others have said, please continue to add pics
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Re: Halfway there
    Bruce - Really appreciate your input. I'll talk to the builder on Monday. I looked at the calculations in the permit pack & want to double check his flow rate and filter choice (the PLM-150 seems better suited). The max dynamic head calculated is ~40 ft; he is using 3" branch, 2.5" trunk, and 2" return piping.
    If I add solar (positioned on the other side of the house from the pump and about 12 ft above the pump) then my rough numbers using Univ. of Florida reference would add about ~20 ft of head to that (panels +4, 80 ft of 2" PVC +6, static head +12). Obviously I'll defer to the experts. I got a "D" in fluid mechanics but a "B" in water chemistry.
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Re: Halfway there
    Matt - I really wanted more of a Roman look, but that would have bumped up the cost for the enclosure to get 30' of swimable length.
    -Taz
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Halfway there - Day 25
    Tile guys came today. Photos below.
    Hope the footer can be dug & reinforced tomorrow
    Re: Halfway there
    We have the same tile. Everybody loves it and it makes the pool look even more blue. You pool looks like its going to be wonderful!
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Re: Halfway there & Holding
    Footers for the enclosure dug; electrical & footer inspection done; concrete for footers to be done on Monday.
    BUT, the pavers are delayed (that's what I get for ordering slate look pavers http://tremron.com/products/ourprodu...tonehurst.html in a color other than gray) which delays the enclosure and the plaster. Sigh.
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Progress! Footers poured, pavers are done. Waiting for the enclosure sub-contractor (there's one job now ahead of me). Here are a few photos of the pavers.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    Re: More than Halfway there
    Love the pavers and the pool shape . You might want to run electrical conduit to the four corners of your screen and also water at all corners. Also you might want to run water and electrical to future summer kitchen. If you have a large sub panel you can tap off power from there. You can never have too many electical outlets. DW always finds things that light up to plug into them especially around christmas time
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Re: More than Halfway there - DONE
    We've been shivering with antici ...... ....... pation waiting for our pool to be finished. And it is - more or less. Timing is everything and waiting 3 weeks for the enclosure sub to start was painful. A quality job - the inspector was pleased. But that's water under the bridge/in the pool.
    The installers did a light acid wash as the fill began. Turned off the hoses at 0600 this morning (kept waking up to check the level). The water is cloudy with plaster dust so hopefully they'll be by in a few hours to start the pump & continue the startup.
    Here are a couple of photos. More once they cleanup the area & we jump in.
    Cheers - Taz
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    Re: STILL -More than Halfway there
    Looks great congrats.
    chessie6's Avatar
    East Hartford, Connecticut
    187
    Love the tile you chose . . the pavers . . everything! Have many wonderful days swimming in your new pool
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Aug 2010
    Cincinnati, OHIO
    17
    I love the pavers and coping.
    Where are the pavers from?
    Is the coping pre-formed or poured?
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Quote Originally Posted by R_Willis
    Thanks - my wife has the eye for matching stuff.
    Concrete pavers (Stonehurst design/Riverwood color) and coping (Sandstone color) are Tremron products
    http://tremron.com/preview/products/...-38pavers.html made in FL. Pavers have a "slate look" texture - would look great in grey. The coping bricks ( http://tremron.com/preview/products/...rbullnose.html )are mortared into place on the edge of the concrete wall.
  20. Back To Top    #20
    Congrats on a great looking pool.
    25x25x16 L shaped concrete, 4' to 6', 21,000 gal, PLP4 - Pro Logic System Control & Aqua Logic Salt Chlorine Cell, Hayward TriStar 1 HP, 24" Sand Filter, SunHeater Solar Heating System, ColorLogic Light, Jandy deck jets.
