Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Measuring PH accurately
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I'm having a difficult time getting an accurate reading of my PH.
    I mean, I never thought I was color blind until I try telling the difference between 7.4, 7.6, and 7.8. They are soooo close.
    I feel like there is a big difference and Im thinking that mine might be dark enough to be 7.8. But Im not sure. Is there a trick or different test to find out exactly what it is?
    The chlorine test is the same to me. All those yellows look identical to me
    The difference with the chlorine is that I have the 100 test kit which is amazing and I just do the chlorine drop test and find out exactly what is going on. For instance, the other day I thought my FC was over 5 from the yellow test. It seemed dark. But that didnt make sense so I grabbed the chlorine drop test and it was 3.5 which was perfect.
    But I cant do that with PH.......
    Any advise on this?
    Thanks guys!!!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    30,421
    Re: Measuring PH accurately
    Hey,
    Short of a VERY expensive digital meter, you just have to "wing it".
    Getting someone else's opinion or practicing several times is always a good idea.
    Fortunately, the difference between 7.3 and 7.6 is of virtually no consequence for our purposes with pools so if you get close, you're fine.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Glad my daughter is home for the summer (young eyes)!
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    A little trick I learned a long time ago from an old timer whose eyes were about the same as mine now was to read the color scale in front of a grey scale panel, he actually used a newspaper which had a large section of grey area on it. Today I use a photo grey panel that I use for photography behind the scale since I have a few of them and use them for the photo hobby but really anything that adds a grey tint works well for distinguishing color levels. It doesn't help with color distinction as much as it helps with darkness levels which is what is the hardest to see for tired/older eyes.
    Give it a try and make sure to use sunlight instead of incandescent or fluorescent light, see if it helps.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Jan 2009
    Cupertino, CA
    1,966
    If you are using the OTO (yellow drop) chlorine test at the same time as the pH test, read pH first. Staring at the yellow before looking at the red/orange can change your perception due to color fatigue. (I had the same pH test go from 7.5 to about 7.9 after looking at the OTO.)
    --paulr
    BBB "Intermediate Swimmer"
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by 4JawChuck
    I will definitely try that. It makes perfect sense actually. I have a home theater that I use a grey scale screen on because it helps with the darkness levels and color distinction
    Thanks for your help!!!!
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by PaulR
    --paulr
    That's interesting. I always do both tests at the same time and Im pretty sure I look at the Chlorine first just by habit. Ill try it that way and see if it makes a difference.
    Love the gray scale idea though.
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    I have a grow light for starting plants indoors that helps me. I put the block under it with white background and the colors pop. I was suspicious at first so I would test the chlorine with the drop test and was dead on every time. They're cheap to boot at walmart.
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    RenegadeT's Avatar
    Apr 2013
    GSO, NC
    28
    phew, its not just me struggling with the pink/orange pH
    TF100 kit, 26k Gallon 18x36 Vinyl inground by Blue Haven Pool, TurboCell T-15 SWG, SmartPure ozonator,
    Hayward SmartFilter cartridge with 1.5hp dual spd. Hayward SmartMax Star Pump.
    Smykowski's Avatar
    Sep 2011
    3,065
    I like the gray background suggestion.
    I find I get my best reading by holding the comparator block against bright blue sky.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    I get my best results holding the block at arm's length with a white resin patio chair as the background and squinting until the numbers are unreadable. I can tell if I'm closer to 7.5 or 7.8 no problem.
    30,421
    Blue sky works best for me, but I think it is a matter of finding a technique and then sticking with it over and over and you will get proficient.
    Apr 2012
    Newton, NC
    173
    The FC/pH test kits include a white blotting cloth. I never use it and just save it to hold behind the tubes so I have a nice white background. And, as others have said I read it in natural light. It is amazing how much different the colors look under natural, incandescent or fluorescent lighting.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    30,421
    the colors going from low pH to high pH are....
    yellow 6.8 and lower
    yellow orange 7.0
    orange 7.2
    orange red 7.4-7.5
    red 7.6-7.8
    red violet 8.0
    violet 8.2 and higher
    These threads come up often.....naming the colors seems to help some folks.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I use the white brick of my house. I have considered buying an electronic meter...but that will take significant research before I jump.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Oct 2007
    Valrico, FL
    542
    An electronic pH meter is not all that expensive. A low end model can be had for under $20. You will of course have to calibrate it on a regular basis.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Jul 2012
    CA
    240
    Quote Originally Posted by dschlic1 View Post
    How do you calibrate it? I was given one without operating manual.
    The least expensive electronic meters can't be calibrated, and so are useless. The mid-rage ones all use different sequences to calibrate, so you need to find a copy of the manual (often available online).
    I would not trust a PH meter that costs less than $100. It might work for a while, but the less expensive ones are amazingly unreliable. They provide the illusion of precision, while lacking any true dependability.
    Unless you have significant color blindness, or need to measure PH several times a day every day, the color matching PH test really is your best choice. The extra effort required to keep the electronic meters in calibration is more trouble than it is worth otherwise.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    For years now I have used the Lamotte ColorQ. It is very good and I do check from time to time with a regular test kit and I have to say, it's always close if not almost right on the money.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
  20. Back To Top    #20
    Jul 2012
    CA
    240
    There needs to be a TFP youtube vid on how to post youtube vids, lol.
    Is this a decent brand? are those pills still good?
    Heres the link http://youtu.be/vvNIGh-qZek
    Quote Originally Posted by ps0303 View Post
    So out of the two what one would be the definite reading?
