Results 1 to 8 of 8
Thread: Spare Motor
    Spare Motor
    I am looking to buy a spare motor for my pump or should I get a new pump and motor together?
    I want the most efficient 2 speed motor (i believe it's the AO Smith B2983). This motor is around $305.
    I currently have the Waterway SVL56. Is this a decent pump or is this the time to get pump/motor.
    If I do the pump/motor I don't know that the pump manufacturers states the motor they are using?
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    22,553
    Re: Spare Motor
    The big qestion is why do you think you need to have a spare motor?
    Re: Spare Motor
    So when my current one dies I have a speedy replacement. My last motor only lasted two seasons and died on a saturday night before a big party. I had to scramble to find a replacement.
    Test Kit K-2006c
    22,553
    Re: Spare Motor
    If that's the reason I'd buy an entire pump. Next time it might be the wet end that goes out.
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Re: Spare Motor
    Thats what I did and now have a spare on hand in case this 2 yr old pump or when this 2 yr old pump goes out. Then its just a matter of swapping the pumps out. Everything happens on a weekend when nobody is open. Never fails including when I go farming to my family farm here in ND. Drives me nuts!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Re: Spare Motor
    A complete pump and motor is easier to swap in a hurry than individual pieces, just make sure you test it before you place it into storage to make sure it works before the warranty runs out while it sits.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Re: Spare Motor
    Any opinions on Waterway Pumps? I am thinking of just getting some spare parts (impeller, what really goes bad on a pump, really no other moving parts but the seals) and keeping this pump.
    I want the AO Smith B2983 motor and can't find a pump that comes with this motor. From what I can tell this motor is the most efficient.
    Test Kit K-2006c
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Spare Motor
    The B2983 motor is sold as a more efficient motor because it is a capacitor start capacitor run motor but several pumps have this setup. Also, PSC motors are nearly as efficient. If you are interested in looking at actual measured efficiencies, I would focus the California Energy Commission database. It is the most comprehensive data available. In my sig, there is a link to a Pool Pump Energy Cost Comparison worksheet they will show the estimate energy use for various conditions based upon the CEC data.
    Mark
