Results 1 to 17 of 17
Thread: Pool water relief in an intex pool?
    Loogootee, IN
    122
    I read Dave's solution to cooling off the pool with a fountain,
    How would I go about getting this to work on a cheap intex pool? pocket book is running low due to 4 complete refills this year only to enjoy it for two days after each fill up.
    I beefed up the filter system on it to a Hayward. But I still have the 1 1/4 connectors. and the regular return nozzle.
    I have tried the running pump at night etc but no luck. the pool sees full sun for about 10-11hrs a day. There is no deck etc. but the few occasions that I got in, you could feel the heat coming off the pool wall. We are getting a new/real pool next spring so I don't want to invest too much money on this one. IE build a deck etc.
    Would getting Styrofoam insulation panels and putting them up against the outside pool wall help any?
    Someone please save me from my Wife and two girls killing me due to hot water!
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pool water relief in an intex pool?
    I'm about 15 miles north of you, and I've struggled with keeping my inground pool cool as well. It's been as warm as 92 before the last cool spell, and I'm sure it's on its way there again.
    I haven't used my solar cover even once this summer, and I've not had my solar panels on in weeks. You won't have this problem most summers around here.
    A solid cover like a silver tarp that you can get at Orscheln in Washington might work in your case to block some sunlight during the day. Remove it at night.
    Loogootee, IN
    122
    Well hello there neighbor! Thanks for the advice, will have to try that then.
    Jan 2009
    Cupertino, CA
    1,966
    Hey PachinkoPlayer, I remember your story from last year--it helped inspire the Seasonal/Temporary Pool Guide. Hope the only reason you're refilling is the high temperature...
    --paulr
    BBB "Intermediate Swimmer"
    comawhite12's Avatar
    Jun 2010
    South Texas
    56
    Hello all.
    My water was out of control! Got in it in the evening and it was bath water. Pool gets full sun all day, and beings I am in South Texas the temps are over 100 daily.
    This is how I got it to drop. All pipe is 1 1/4 pvc. The fitting is the one for the intex skimmer. It is the one for smaller pools that fits the 1 1/4 thread fittings for your pool strainer.
    I have it all just press fit together untill I find another fitting to glue everything to. Also, this now appears hard to find so if anybody has one they will part with let me know. gotta gotta have it. .
    I had to drill alot of holes due to my 2500 gph pump blew the entire contraption into the pool with only 6 holes.
    I ran it from 4 pm till 7 pm, and the change in water feel was amazing. If you ran it all night I assume it might be down right chilly. PH will rise, but I can drop that pretty easy.
    Hope this helps.
    Oh, and total cost of goods including pvc cement and primer.....$15.25 @ home depot.
    15' Intex frame set
    4600 Gallon
    2650gph Intex Sand Filter
    NightLighter 35W
    Red Neck fountain
    Jun 2010
    South Texas
    56
    A few more.[img]
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Do the intex pools' 1 1/4 returns have a threaded or a smooth interior?
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    South Texas
    56
    They have a 1 1/4 rubber tube that the insert slides into.
    The insert is a snug fit in the tube and has a male 3" threaded plate that the fittings attach to inside the pool.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    I think this is the adapter http://www.intexstore.com/ProductDetail ... ductID=139 that was used. Unfortunately, it is out of stock on the Intex web site. Even though it says for pools 16' and under, my 18' metal frame has two sets of threads, one of which fits this adapter. I bet you could also make this adapter work http://www.intexstore.com/ProductDetail ... ductID=690 and it is in stock.
    It's good to know that 1.5" pvc fits this adapter. That opens up a world or modifications. I am considering a change to pull water from lower in the pool into the pump. Right now the skimmer pulls water from the top and the return is only a few inches deep. Even with the return eyeball pointing down and away from the skimmer, I'm not sure there is enough mixing going on.
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Jun 2010
    South Texas
    56
    Yea, that first fitting is the one I used. Not sure by looking if the second one could be made to work tho.
    Also, just checked Intex's web site. No longer out of stock. Just placed my order.
    Dont know if you have found this little gem yet. topic25132.html
    I plan to do this on the off season once I cut my larger holes for the 1 1/2 fittings that came with my 2500 gph.
    Good luck
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Did you have to do any trimming or adjusting to make the 1.5" pvc elbow fit the adapter? Does it fit tight without gluing?
    I have the same fitting that came with my Deluxe Skimmer. Since I only have a 1500 gph pump I don't think my skimmer would work if I did the mod shown at that link. What I was thinking instead was to buy a second adapter to connect to the return side to lower the return.
    Jun 2010
    South Texas
    56
    Nope, no trimming needed. It fits in nice and snug. I am ordering another one so I CAN glue the fitting to it. It tends to fall over after a while.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Jun 2010
    South Texas
    56
    Sorry. Was just in the pool enjoying the cooler water when I got a good close look @ the pvc. It is 1 1/4" not 1.5".
    Hope no one ran out and bought the wrong stuff. I also have edited the above post, so no......you were not imagining things.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Jun 2010
    South Texas
    56
    Update.
    I finally cut the liner to install the larger fittings that came with the 2500 GPH pump. Did it all without dropping the water level. Might have lost 1 or 2 gallons during the procedure.
    I am now getting at least 6' of air on the top of the arc. Loving the cooler water temps.
    15' Intex frame set
    4600 Gallon
    NightLighter 35W
    Red Neck fountain
    Did adding the larger fittings for the 2500 GPH pump improve the suction on the intake valve? What did you use to mark and cut the lining for the larger fittings?
    Jul 2014
    Houston, Texas
    5
    Wow that looks really cool. I was wondering if my pool with only 4,500 gallons is going to heat up under the blistering Houston sun; the pool is for cooling off, not to feel like soup water. Hopefully this is an easy fix. Thanks for sharing.
    Helena
    Intex Ultra 18' X 9' X 52" (4,545 gal) AGP
    Intex Sand Filter Pump Combo 1,050 gph
    Intex Krystal Clear Saltwater System 15,000 Gallons
    Gorilla pad sitting over crushed gravel base
    jmcdtucson's Avatar
    Jun 2014
    317
    Holy cow. I'm in Tucson, AZ where it regularly hits 105-109 and my pool is the perfect temperature (not trying to brag, just thankful). Must be something to that "dry heat"
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
