Thread: Cannot maintain chlorine
    Mar 2010
    Ridgeway, SC
    25
    OK, I think I may know where I am and what I need to do, but ask you experts for help...
    FC - 1.0
    PH - 7.5
    TA - 110
    CYA - 40 (added Pool Calculator recommended CYA 2 days ago)
    CH - 300
    I have a SWG. My daily tests of FC have not exceeded 1.5. I add Pool Calculator recommended amount of bleach each day, and, next morning, back to same low level. Is my SWG not generating chlorine (new cell last year - all lights green)? Do I need to wait for the CYA to stabilize and maintain with bleach, and then do chlorine demand test? Or, do I do chlorine demand now? I question because I believe the thought is that after adding CYA, it takes a week or so to get accurate readings?
    Thanks in advance
    Oldogface
    17,000 gal fiberglass. 1.5hp pump, Pentair 60 sf DE filter and Pentair IC-20 SWG, TF Test Kit, BBB
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Re: Cannot maintain chlorine
    Quote Originally Posted by oldogface
    What is the Combined Chlorine? Perhaps something is consuming your chlorine. Happened to me. In which case, shock is the answer.
    With Aqua Rite you can tell if it's generating chlorine by the bubbles coming out of the returns.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    With a SWG, it is very important that the CYA level be correct. The recommended CYA level with a SWG is between 70 and 80. At significantly lower CYA levels, there is no way the SWG can keep up with the chlorine demand. Until your finish getting the CYA level up, you should manually add extra chlorine to help the SWG keep up.
    Feb 2008
    Denton, TX
    5,061
    I would suggest manually dosing your pool with liquid chlorine or bleach this evening and then doing an overnight FC loss test. Shut the SWCG off after the sun sets and check your FC. Then, check it again in the morning before the sun hits the water. If you lose more than 1 ppm FC overnight, you need to shock your pool.
