Thread: Thread Compound?
    Jun 2010
    Fremont, CA
    293
    Thread Compound?
    What kind of thread compound do you recommend for PVC threaded connections to pumps?
    Thanks for your thoughts,
    Jeff
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    Re: Thread Compound?
    I'm using master plumber with PTFE, but most brands should work provided the label approves use on pvc etc.
    22,544
    I've used Master Plumber and Oatey Great White. Just make sure the container says it's safe on plastic threads.
