Thread: Connecting Fountain
    Connecting Fountain
    I bought a simple PVC fountain/aerator to try and keep the pool a little cooler but am having trouble installing it. The fountain has a male, threaded 1 1/2" end. I unscrewed one of the return eyeballs but it seems to be 1 5/8" or maybe metric (also male threaded). Since it's not a standard PVC size I haven't been able to find any kind of adapter/connector that will let me connect the fountain to the return.
    Any ideas?
    Thanks
    16,500 gal, In-Ground
    Pebblesheen Prism Blue (replaster 3/2010)
    DE Filter
    1.5 HP Pentair Challenger
    TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Connecting Fountain
    You may have only gotten half the fitting. Are there two notches on the front face of the threaded portion still in the pool wall? If so, this unscrews, leaving a female threaded portion that is slightly smaller than the outer thread.
    22,537
    Ah, I just saw the "male threaded" statement. You most certainly have only removed half of the fitting, as John said.
    Yup...that was the problem. Got the fountain hooked up last night so, hopefully it will keep the water temp a couple degrees cooler.
    Thanks!
    DE Filter
    TF-100 Test Kit
