Thread: First week - New Pool in NJ
    Feb 2010
    Central NJ
    53
    Well We finally finished out new Gunite Pool. Startup company come over and explained brushing, backwashing and chemicals. additionally he had some suggestion that I want to run past you veterans. Plis i have my own questions
    1 -Been brushing 3 times a day for the last 5 days. My "Day 1" clean pressure stared at 10psi and I was back washing at 20. slowly my post backwashing pressure is now 20 psi. Is that normal?
    2 - also, my water is crystal clear and I do not see any dust coming off as I brush. My pressure is remainig at 20 psi but my return pressure is still stong. should I backwash? I now havent backwashed in 2 days
    3 - As of now I have been using mostly PH Down but have also added some algecide. When Do I add chlorine and start swimming?
    4 - Start up guy recommended expansion gap caulking in place of my styrofoam the patio contract left in there
    5 - I have very small bubbles comng out of one of my returns. Ive done a search and it seems most are due to SWG, but I don't have an SWG yet. I have N2 but havent added the mineral pod yet to the canister. Do you think I have a leak?
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    22,553
    Re: First week - New Pool in NJ
    1) When you backwash are you adding new DE to the filter? It may be time to break the filter down and clean the grids.
    2) See number 1.
    3) You should have been adding chlorine since the beginning. If it's been a week you probably have the start of an algae bloom by now. Use Pool Calc and add chlorine sooner rather than later.
    4) I agree with the startup guy. Caulking is way better than styrofoam.
    5) Yes, you have air getting into the system somewhere on the suction side. The pump strainer lid is a common place for that to happen.
    You should get a good test kit if you don't have one already. You should also NOT use the N2's mineral pak. You can do a search for nature2 here and find out about them.
    Feb 2010
    Central NJ
    53
    Yes - Im adding new DE each time I back wash. In fact I add slightly less then the equipment calls for. Im adding 5 lbs. for a DE60 which calls for 6 lbs. Can it be I need to clean my grids after oinly 1 week?
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Quote Originally Posted by Dominick
    Yes. Especially if you're loading the filter with concrete dust. You've backwashed, what, 5 times? That's like 2 years' worth for me!
    Feb 2010
    Central NJ
    53
    Can't wait to get to that point.
    Im going to call the pool service tech to clean the grids. Hopefully they'll show me what to do so I can do it myself going forward
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    22,553
    There are several threads here about cleaning DE grids. If you're feeling froggy jump right into it. There's not a lot to it.
