Thread: Adjusting 'baby barrier' style fence
    Livermore, CA
    32
    Hey all,
    I've got a 3 yr old baby barrier style fence that has apparently sagged a bit over the years, and i need to re-tension it. The gate hangs a little low right now,and as a result the gate wont latch without a push. If I squeeze the gap between the section with the gate and its neighbor it goes right back to where it should be and latches perfectly.
    So is there a proper way to re-tension these, or do I just need to start playing around with it?
    Darren
    ~20K gallon freeform w/attached spa
    Pentair 4x160 pump
    Pentair Mastertemp 400K BTU heater
    Intellitouch i7+3 controller
    Intellichlor IC40
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Adjusting 'baby barrier' style fence
    A picture would help a lot.
    What I'm envisioning can probably be fixed with a couple of screw eyes, some wire, and a turnbuckle. That's so when it sags again, you can just crank it a few more turns and be done.
