Thread: Cloudy Pool
    Jul 2008
    Seacoast, NH
    250
    Cloudy Pool
    I've been a BBB user since our pool was built in 2008. I'm a big believer. It's been going pretty well, but I'm having a problem today. My water is cloudy.
    Here are my numbers as of this morning
    TC = 3.5
    CC = 0
    pH= 7.4
    TA = 80
    CH= 175
    CYA = 40
    Salt = 2340
    I added 120 lbs of salt. I know my CYA is a little low for a SWG, but I'm having trouble getting it higher. Every week I add 1-2 lbs and it barely moves.
    We're having a heat wave here, 95 degrees. I know you in TX are laughing at me, but for NH that is HOT. So yesterday we had 5 ppl in the pool, today 4, all adults.
    After the swimmers got out of the pool this afternoon I added a 128 oz bottle of 12.5% shock. A half hour later the TC was 1.2 and the CC was 0.2. Weird. The shock was a little old (bought maybe end of May), but that really seems like something is wrong. I added another bottle of shock, bought at the same time, and a package of 52% Cal-Hypo. I also turned the SWG up to 80%. Usually it is fine at 20%. The salt is 3110 now. I haven't retested the TC.
    I'm concerned that the cloudy water and the low TC may mean an algae outbreak is coming. But, if that were the case, wouldn't the CC be higher?
    Any thoughts or advice? Thanks.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Jul 2008
    Seacoast, NH
    250
    Re: Cloudy Pool
    Just checked the TC. It's 6.5
    1.5 HP Pump
    30,421
    Re: Cloudy Pool
    The cloudiness was perhaps due to a heavy than normal bather load and then the Cal-Hypo you introduced. I'll bet it will be gone tomorrow. Run your pump 24/7 meanwhile.
