Thread: All levels are fine, but TA is going up. Does it matter?
    Bob47's Avatar
    Baltimore, MD
    10
    I've had the pool up and going since mid May. It was way out of whack and I found this site and it as been a beautiful experience since then. Clear, sparkly, wonderful water!
    Been keeping FC between 4 and 8 (as advised here) since my CYA is at 50. CC almost always zero, rarely it gets to 0.5. CH is at about 90 and PH has stayed rock steady at 7.5 for over a month.
    The only issue is TA. It started at 150. Once everything else got to good levels it went down to 100. It's been creeping up for the last month and is at 140 now. Is this something I need to worry about since everything else is good?
    I'm a bit confused how TA and PH can vary so much and I don't want to go mucking about tinkering with the chemistry unnecessarily.
    Bob
    Baltimore, MD
    5300 Gal, 15' Round AG, Vinyl, 1.5hp pump, Cartridge Filter
    Feb 2008
    Denton, TX
    5,061
    Re: All levels are fine, but TA is going up. Does it matter?
    If you keep your pH in check with acid additions, your TA should kinda handle itself. If you find that you need to lower it though, you can follow the directions for Lowering Total Alkalinity to take care of it.
    Bob47's Avatar
    Baltimore, MD
    10
    Good to know. Thanks!
    Bob
    Baltimore, MD
    If this continues happening, you should test the TA level of your fill water. It is possible to have high TA fill water, that drives up the TA every time you top off the pool.
    Bob47's Avatar
    Baltimore, MD
    10
    Didn't think about that. I topped it off earlier in the day.
    Thanks!!!
    Bob
    Baltimore, MD
