Results 1 to 7 of 7
Thread: A few quick questions about pH
    Jun 2010
    Elkridge, MD
    104
    Does lack of filtration cause the pH to rise? My pH is usually around 7 (I try to keep it up, but it keeps going down), but on one recent test I was surprised to get a bright red that looked close to 8.
    Would lack of filtration/aeration (The filter shut off for a few days unbeknownst to me, and I also haven't been swimming in about a week) do this? Or was it something else?
    The pH is now back down.
    Does this mean I should run the filter less often? How come my pH always wants to come down? Eventually doesn't it get ENOUGH Borax??
    Thanks
    32 x 16 20,000 gallon inground vinyl. Pool Genie filter. BBB seems to be working well so far despite high CYA. Aquabot Turbo T which I adore.
    30,432
    Re: A few quick questions about pH
    Pump running or not has little to do with pH as a rule. The most common cause for pH going down is the use of pucks to chlorinate. Posting a set of test results may help us see something so just take the above as a guess.
    Jun 2010
    Elkridge, MD
    104
    I'm usually around 7 FC, 7.0 pH despite efforts to keep it up, 140 TA, 90 CYA. My pH just read very high one single time...maybe I just put in a drop extra by accident??
    30,432
    The number of drops in the pH test is not deadly critical......4 or 6 drops should return the same pH as 5 drops.
    Jun 2010
    Elkridge, MD
    104
    That's very strange. I am used to fluctuating between 7.0, and 7.4 when I address it. That dark red came out of nowhere!
    Feb 2008
    Denton, TX
    5,061
    What test kit do you have? Did you happen to switch to a new bottle of pH indicator solution? If you normally use Taylor R-0014 pH indicator for your testing and happened to buy a bottle of R-0004 pH indicator as a replacement, you might end up with this type of problem as the R-0004 calls for a different test block.
    Jun 2010
    Elkridge, MD
    104
    I have the Taylor K-2006. It uses the R-0004...I did actually buy a replacement bottle, but I checked and that's R-2004 too.
