Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: What are the absolute worst substances that could be put in?
    Jun 2010
    Elkridge, MD
    104
    This is just for curiosity's sake--I'm not looking to sabotage my pool or anyone else's. I'm just wondering if anything could go in there that would make really really bad things happen to the pool and/or the people in it!
    32 x 16 20,000 gallon inground vinyl. Pool Genie filter. BBB seems to be working well so far despite high CYA. Aquabot Turbo T which I adore.
    Re: What are the absolute worst substances that could be put in?
    Chemgeek, Jasonlion, and our other very knowledgeable pool folks (especially those who have probably had to clean up a mess or two in their professional careers) will chime in I'm sure. And while I don't know about permanent damage, there has been posts in the past of people having their pool sabotaged with oil. The guy who had it happen had to make a boom to skim it off the surface and shock & shock and change his sand too I think. Makes you want to catch the person who did it and probably beat the stuffin out of 'em.
    17k gal., sorta IG vinyl, 1.5 hp pump, 21" sand filter, EZVac cleaner
    Jun 2010
    Elkridge, MD
    104
    Yeah, oil was one of the things I was thinking, based on not only the Gulf situation, but also because I'm the kind of person who would decide to jump his bike into the pool after a few beers
    Well then you would be adding gasoline & oil & break fluid, possibly antifreeze depending on the bike and maybe battery acid. I ain't swimming in your pool then
    Jun 2010
    Elkridge, MD
    104
    No not a MOTORCYCLE, even I'm not that stupid But my bicycle would still have grease and chain oil.
    Feb 2008
    Denton, TX
    5,061
    Okay, I can no longer resist...the absolute worst thing that you can put in a pool is...
    A 200 pound block of 100% pure metallic elemental sodium.
    That would be bad.
    I'll bet that Richard could top my suggestion though.
    Jun 2010
    Elkridge, MD
    104
    heh...I did a bit of research on the sodium...
    http://www.periodictable.com/Stories/011.2/
    ...not sure exactly where the line is between THAT'D BE AWESOME and MAN DON'T EVEN THINK ABOUT IT...but it's probably well under 200 pounds
    Feb 2008
    Denton, TX
    5,061
    In all seriousness though, the things that under normal pool circumstances, I would consider the be the worst for introducing in a pool would be just about any hydrocarbon or a big bunch of fertilizer. Gasoline seems to me to be something that would really be tough to deal with, even more so than straight up oil.
    Quote Originally Posted by 257WbyMag
    That would be bad.
    hehehe mythbusters did that in a smaller amount. big boom. but they also did it with something else that provoked more of a reaction then sodium, but i can't remember what it was.
    now that you mentioned gasoline, i would agree that probably would be the worst. if memory serves there is a chemical added to gas, MTB(??) maybe that gets in to the groundwater and permanently pollutes it, no way to remove it. guess you'd be draining and refilling plus changing filter medium plus i'd be very concerned about it leaching in to the piping/liner/filter/etc.
    ddpool's Avatar
    Jul 2008
    Minnesota
    61
    A BabyRuth
    Coming Soon: In-Ground
    Previous: 24' Round AGP, 2HP Pump, Sand Filter, Solar Cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Crude oil would be bad. So would Plutonium. Or this guy could empty his load in your pool:
    Jan 2008
    Northeast Florida
    161
    Recently at a family event, a toddler left a turd in the pool. As various family members freaked out, evacuating the pool and suggesting we drain it, my FIL casually picked it up with his bare hands and said "No need to worry, it's clean, it never even touched the ground, 2 second rule"
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    In my experience the worst thing I ever had to deal with was the one time my boss decided to dye our pools green for St Patty's day.
    Sure the label said it was 100% safe for plaster pools but what it didn't explain is how it attaches to the grids of a DE filter...and stays there....until the grid sprouts a hole in it.....and then dumps it's St Patty's day green contents...... all back into your pool.
    I got good at replacing grids in DE filters that summer. 9 complete grid change outs.
    lmao
    Here's some scary thoughts:
    Broken glass (never allow any glass products anywhere around your pool) Once my daughter dropped a light bulb right by the pool- luckily none of the glass got in it- whew!)
    Paint (oil base is worse than water based, but wouldn't want either!)
    Regular diaper (as opposed to a swim diaper- yeah, my sister in law put her kid in our pool once with a regular diaper- it immediatly absorbed 20 pounds of water and then chunks of goo went all over)
    Poo- (once a neice pood the pool- luckily I just had to remove the turds and shock) (and once my youngest daughter pood her swim diaper in the pool and it was a loose one- the swim diapers catch chunks, but poo water was dripping all over- another major shock event)
    A pet peeve of mine is when people come over and put a whole bottle of sunscreen on and then want to immediately jump in the water. I make them wait at least 20-30 minutes to make sure it's absorbed before they get in (a good test is to wet their arm or leg- if it immediately turns white, then it's not ready- if they get in too early, all the sunscreen comes off, clouds the water, creates a terrible scum line, and they sunburn and think it's your fault)
    A potted plant- keep them far enough away so that they don't get knocked in or blown in by the wind.
    Pool furniture (especially if you have a vinyl liner that could tear or puncture).
    Animals (once the outside cat was drinking out of the pool and fell in- it was funny to watch, but could have punctured the liner clawing his way out- luckily somehow he didn't). I also think it's totally gross to let your dog swim in the pool unless he's bathed and brushed frequently. Haven't had any problems with snakes, but we've had a few shrews end up in the skimmer basket- gross!
    Trees- when hurricane Gustav blew thru, an oak tree fell right between the house and the pool- MAJOR mess, but we got lucky again and although there were lots of leaves and sticks in the pool, nothing hurt the liner. The sap that dripped all over the pook deck took forever to clean up!
    Body jewelry- true story- went out of town on vacation and my brother in law house sitted for us and had a pool party- when we got back, the pool was milky cloudy and we found a body piercing ring on the bottom of the deep side (not sure what part of the body it was from or whose it was!- GROSS)
    Intoxicated guests- you know they're gonna pee the pool- watch the CC
    Vomit- just gross
    14'x28' vinyl liner inground 3.5-6' deep wedge hopper 15000 gal (used to say 13000- I calculated wrong), 1 hp pump with sand filter, 2 returns, 1 fountain, traditional chlorinated, pool house.
    Guest
    Personally, for me, it would be my ex wife
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Quote Originally Posted by simicrintz
    My first thought was a bag of cement. (Not for the ex-wife, but as the worst thing in the pool. Of course, the bag of cement might solve the ex-wife issue also )
    24' AG Round (vinyl replaced 0909) - 13500 gal - Sand Dollar Filter (150lb) - Dynamo DYNII-N1-1 1HP - Hayward HP380 Heat Pump - TF-100.
    Central Missouri
    Before I speak, I have something important to say.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Guest
    Quote Originally Posted by TimS
    My first thought was that you were on to something, and then I realized not only would she be in the pool, but how would I get her out
  20. Back To Top    #20
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Do they make a sequestrant for that?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
