Results 1 to 7 of 7
Thread: Question about Taylor K-2006 test kit
    Jun 2010
    Elkridge, MD
    104
    If I am understanding the instructions properly, for the chlorine test you put 2 dippers into 25 ml of the water, and each drop that eventually turns it clear counts for .2 ppm; or you put 2 dippers into 10 ml and then each drop represents .5 ppm.
    I am running a high amount of chlorine and CYA, so I want to use just a 10ml sample to save time and money. But how come the dipper amount is apparently the same when everything else is scaled? Am I doing it right?
    32 x 16 20,000 gallon inground vinyl. Pool Genie filter. BBB seems to be working well so far despite high CYA. Aquabot Turbo T which I adore.
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    Re: Question about Taylor K-2006 test kit
    You can do the test either way depending on how accurate you want to test. In most cases, the 10ml test sample will give you as much detail as you need for your pool.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Jun 2010
    Elkridge, MD
    104
    But how would the same amount of the dipper stuff be appropriate? I'm not understanding why that wouldn't change on a percentage basis, like the water volume and drop representation are.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You just have to have enough for the chlorine to react. Extra doesn't matter. One scoop might do for low chlorine levels, but you'll need more for higher levels.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    I have often wondered this. Every time I place an order with one of the folks at Taylor, I forget to ask about that business. It sort of bugs me because the beloved powder/crystals are rather expensive. However, to date, I have never gone by my own rules. I follow their rules.
    2 scoops.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    One way to look at it is that you have a lower maximum FC level that you can test when going by 0.2s. A lower maximum chlorine level combined with a larger water sample means about the same total amount of chlorine in the sample, so about the same amount of R-0870 powder required.
    Jun 2010
    Elkridge, MD
    104
    I read this three times and still don't understand it...but if you're all telling me I'm going it right, that's good enough for me
