Thread: electronic tester
    electronic tester
    are there any, or does any one use an ectronic tester for water that test all the things that need testing?
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: electronic tester
    IF there were and it was reasonably priced, I am sure TFTESTKITS would sell it.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Jul 2010
    Allen, Texas
    5
    I just saw one at Leslies today...kinda looked like a BG reader...it was buy the water testing station....
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    None of the affordable electronic testers are as good as the TF-100 or K-2006. The best one for home use is probably the ColorQ, but even it has some quirks that require extra attention is some situations.
