Results 1 to 16 of 16
Thread: Why can't I see bottom of deepend?
    Kendall Park, NJ
    16
    I am a new pool owner, this is my 2nd post. I started the shock process over a week ago, thanks to this forum! Pool really looks great with clear water. I have some pictures attached below. I think I have a leak in the liner, loosing more than an inch & half a day, I have left several messages for pool service guys but because of holidays no one has returned my calls, they must be really busy in my area! I fill everyday to maintain level so I can continue to fliter.
    Water at shallow end of the pool is clear & steps and bottom are clearly visible, howver I can not see the deepend bottom at all. I am continuing to shock & trying to maintain FC 15 (pool calc syas 12) bit higher thinking that water will get clearer soon. I see no end to this process. I bought an Aquabot T2 which is working full time with pump on 24/7 for several days now, I still cant see deppend bottom!!!
    I did overnight FC loss test and loss is zero. here are my numbers,
    FC 15
    TC 15
    TA 90
    CH 110
    CYA 30 - 35
    pH 7.5 may be bit higher
    Br 10
    What am i doing wrong? my questions are,
    1) should I continue to shock at 12 or 15? or maintain FC levels of min 2 & target 4 based on my CYA 30?
    2) Should I continue to run pump 24 hrs/day?
    3) should I continue to run Aquabot T2 full time?
    4) I read somewhere that I should see the deepend bottom & main drain before swimming is this correct?
    I would appreciate if you can help me end shock process and get water clearer to see bottm at deepend.
    http://i770.photobucket.com/albums/xx34 ... G_1984.jpg
    http://i770.photobucket.com/albums/xx34 ... G_1974.jpg
    http://i770.photobucket.com/albums/xx34 ... G_1976.jpg
    http://i770.photobucket.com/albums/xx34 ... G_1977.jpg
    http://i770.photobucket.com/albums/xx34 ... G_1982.jpg
    Thanks.
    24400 gal, sand filter, IG Vinyl 16x37 Lazy L shape, 3ft shallow & 8ft deep, Hayward 1.0 HP super pump & motor
    Feb 2008
    Denton, TX
    5,061
    Re: Why can't I see bottom of deepend?
    If you are holding your FC overnight and you have less than 0.5 CC, then this is likely just a filtration issue. I would go ahead and keep the pump running 24/7 until the cloudiness clears from the pool. You can go ahead and let the FC fall to normal levels for a pool with 30 ppm of CYA.
    Since you have a sand filter, you might see some benefit by adding DE to the sand filter in order to catch those smaller particles that are suspended in the water. Here's how to do that...
    pool-school/add_de_to_a_sand_filter
    30,402
    I agree with 257 that you likely have a filtration issue. When did you last backwash? When did you last inspect your sand? Does your psi guage work?
    Apr 2010
    hurricane deep south
    24
    My newbie opinion: If i were you, once the FC is at normal level, I would confirm and address the PH. For me, the PH is my visual clue when it comes to clarity.
    Also, it might help to check that the skimmers and returns are flowing correctly. When I got my house my valves were at odd settings and one of my skimmer baskets was floating instead of down.
    33K IG 1967 45' X 20' Roman 4-8 ft plaster/gunite. Triton Sand, 1.5 HP pump. Indoor with Screen Atrium top. Bought a Swamp with Nails Glass and Trash with An Algae Encrusted Astroturf Surround. On par and thankful to TFP since 4/2010. A good test kit is your friend! Using a K-2006, refills from TFTest kits.
    Mar 2007
    San Rafael, CA USA
    12,082
    With an 8 foot deep end if there are no operational floor drains or returns pointing downward, then the circulation in the depths of the pool may be poor. Or it could be a filtration issue as was discussed above. Adding DE to the sand filter and making sure the water in the deep end is getting stirred up and circulated would be two things to try.
    Kendall Park, NJ
    16
    Thanks for the quick response & support.
    257 - I read how to add DE to sand filter, thanks. This process seems to be an easy process and would like to definitely try but where can I buy DE? And is there specific brand or form (powder/granular etc..) I need to watch for?
    Backwash was done just recently (2days) and the gauge works fine and now its at 13 psi.
    Just bought the house but previous owner said he had inspected and changed sand either last year or year before, not sure.
    Skimmers & returns seem to be working just fine.
    I’ll drop FC to normal target and then try to hold it there. Then I will adjust pH to 7.2.
    Is there anything else I need to do?
    P.S: My pool is actually 16x37 with 24,400 gals, just edited my sig.
    Kendall Park, NJ
    16
    Chemgeek - I'll try to add DE, where can I buy this stuff? I am sure the aquabot is vacuuming everything there in the deepend. Thanks.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Lowes sells it here in 20 pound boxes in the pool section, note DE has a consistancy about like flour, or even lighter, so be careful not to breathe it in.
    Ike
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Even if the filter isn't doing a great job, that Aquabot should be helping the process being the OP has had it in the pool for many days non-stop. Those things filter the water extremely well.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    This seems to be my catchphrase, but is the main drain working? Mine is plumbed into the second port of my skimmer, and there was no diverterwhen I moved in. I spent about ten bucks on one, dropped it in, and voila! We have flow through the drain.
    Jan 2009
    Cupertino, CA
    1,966
    Make sure you get pool DE not some other kind--it comes in different grades for different purposes.
    --paulr
    BBB "Intermediate Swimmer"
    Kendall Park, NJ
    16
    Sorry for the delayed response, I was busy preparing for the move, still packing...
    I'd like to thank everyone here, my water is crystal clear!! Its unbelievable, I never thought I would get anything close to this clarity being a new owner. Attached are some pictures,
    Above clarity was achieved without DE, I will however try DE soon to see if makes any difference.
    My numbers today are,
    FC 8 - as soon my CYA reaches 30, will drop this to target ~4 or so.
    CC 0.5
    CYA 20 (CYA in skimmer enough to get to 30)
    pH 7.4
    TA 70
    CH 110
    I found all kinds of tools, goggles & other junk in the deepend so it took a long time to clean, also had 10 leaks in the liner (2 on side wall & 8 at bottom deep end - all taken care of), loosing about 3 inches a day for about 7 days, CYA was 0 when i tested yesterday so I am bringing it back to 30.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It sounds like your getting close, good luck with it. Once you get everything balanced it is relatively easy to keep it there.
    Ike
    30,402
    I am thrilled your pool is so clear. It's a great feeling, isn't it? Congratulations on your diligence.
    Rereading this whole thread, I believe the reason your problem was so extended was your lack of CYA. You started with none or very little and then constantly diluted whatever little CYA you did have.
    Having a pool with zero CYA quickly burned up the FC you were adding. That made your clearing process ineffective and drawn out.
    It sure sounds like you have a good handle on it now......Nice work!
    Kendall Park, NJ
    16
    Thanks Duraleigh. Yes now i realize that was probably my main issue why it took so long, but all the junk I didn't know existed down there didn't help the situation either.
    Now that the pool is clear I can finally move on to other things like landscaping etc....
    I would like your opinion however on trouble free way to maintain FC for someone that cant add bleach everyday, would it be SWG or a liquidator? I have done some search here but thought I'll ask anyway. I am leaning towards liquidator to add liquid chlorine or bleach automatically partly because thats the only thing I know and have done in the last few days or so. ..
    Jun 2008
    Texas
    132
    I would not rush into a purchase. You might find that every other day bleach addition is sufficient. Your CYA is not high so you could use trichlor pucks for a limited time. Here is a thread that discusses alternatives: choosing-an-automatic-chlorinator-t11752.html
    The liquidator requires hauling bleach every two weeks. A SWG requires an initial investment but makes a pool as “set and forget” as possible. Many people prefer the water feel of a salt water pool. I recommend that you use the BBB method this summer. After you maintain the pool for awhile you will have a better feel for how you want to add Cl for the long term.
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
