Results 1 to 11 of 11
Thread: What time of day do you run Swg
    I was thinking of doing it at night, or should I do it during the day.
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    South Central NJ
    3,192
    Re: What time of day do you run Swg
    Run in the day. The sun will exact a heavy toll otherwise.
    Scott
    Owner of - PoolGuyNJ LLC
    im kind of confused. I always added my bleach at night. wouldnt it be the same. the swg adds the chlorine it needs to make it through the day.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    22,548
    It really doesn't matter when you run it. The real issue is to get the FC high enough to stay above the min recommended the entire time it's off. So if you run it at nigh you want to check FC in the evening to make sure it doesn't drop below min after the sun has been on the pool all day.
    South Central NJ
    3,192
    When a pool is off at night, neither circulation nor UV will encourage FC to leave the water. For people that add manually, it's usually easier than during the day when they are at work.
    By running the system in the day, fresh FC is being added to recover the lost residual from activity and the sun.
    Scott
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    I run mine from 3pm to 6pm and then again from 12 midnight till 6 am... I guess depends on where you are too-- I am in the deep south and my water temps rise to about 88-92 during the day. So I need the cooling action at night.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    i got to say im at a lower cya than i was before salt water and my fc does alot better. Im hardly losing any. I have stayed at the top of the spec for my cya. really no reason to run swg, but I did for 3 hours last night just to see how much it did. I think Im going to run at night for now and see then try day and see what works best for me.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I run my cheapo Intex starting in the morning but the directions say shut it off when people are swimming. I'm contemplating running it during the night instead. This way I wouldn't have to worry about resetting it after a swim. Still trying to find the best timing to do it, I think I have the length of time dialed in. Really nice not to have to mess with liquid chlorine very often.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    i know. i cant get my fc down. lol. i ran it for 3 hours last night and was still a 9 this morning. i came home 3 or 4 hours later and it was higher. hmmmm generator shouldnt of ran till midnight. so I turned it off. Before I couldnt keep my clorine from dropping like crazy and now I cant keep it from staying up. lol
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    I'm running my '09 Intex in the evening, after the sun has passed off the water. I turned it back to 3 hours today, my chlorine is off the chart. Pool looks good, though. I'm using strips for cya, salt & borates. Salt is dead on, cya says low, borates read almost nonexistent...yet I know how many boxes I've put in, both cya and borax. Hey, water looks great, feels great (tad cool this week after three weeks around 99) so, since it ain't broke, ain't gonna try to fix it.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Thats my feeling now. just dont understand why my FC went up and generator should not have ran. i was adding 50 oz or so a day of bleach at cya of 60 before salt water set up and lower TA. I havent added anything since sat. other than the SWg running for 3 hrs and really didnt even need that. lol. I have stayed around 10 Fc since friday. Im at cya of around 40 or 50 and holding better. imagine that. lol
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
