Thread: residential lap pool suggestions?
    Hello,
    The lap pool is 75 ft long by 16 ft wide, about 6ft deep in the middle and 4ft on the long ends. One small set of stairs, three skimmers, and a very, very basic shape. It is maintained most excellently, but it would be nice to have a little help mid-week so the pool can be used when I'm at work. I've been looking at the robotic options from Nitro, aquabot, and blue diamond, but it seems only the later makes anything for the larger pools? And they are ludicrously expensive. Price point would idealy be below $1k, but if there is something much better in the higher end mark, I will consider. Dirt is mostly bugs, and some vegetation - mostly palm trees (both small and large), but some other standard so-cal leaves. Am I missing other manufacturers?
    Thank you for your time,
    jedo
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: residential lap pool suggestions?
    That's a big pool!! Sorry I can't help with the cleaner though; I know some people here probably can.
