Thread: I was told to push the dirt to the main drain
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Is this right? PSS told me to use scope to push dirt to the main drain...
    Questioning everything.
    (I did a search but did not see any results about pushing dirt to main drain. Perhaps I used wrong query string.)
    Thanks in advance.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: I was told to push the dirt to the main drain
    How much dirt are we talking about? Someone slip with a wheelbarrow?
    If it's just a little, yeah, use the brush and sweep it to the drain - while it's running. Why the PSS didn't sell you a pole, a vacuum head, a hose, a skimmer plate, and anything else he could add on is beyond me. Must be a rookie....
    If it's substantial amounts, like the aforementioned wheelbarrow incident, then a vacuum - to -waste is in order, assuming you have that option on your filter. Otherwise, a vacuum and then a backflush.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Oh sorry Richard! Yes we are talking just minor amounts that collect overnight, not vacuum level.
    Thanks as always - what a great group of people on this forum!
