Thread: under construction, first pics
    Happy 4th everyone!
    It's been a long time since posting last, but we are finally started with the pool. Had some excavating work done to get things going. Have the area rough in and have my ring of crushed limestone in and packed one time. I have a questions for those that have used this method of constructing the base. Is the sand layer enough to guard the line from the stones around the outside? Should some type of liner shield between the crushed stone and sand? I have a lot of leveling to still to fine tune and set the patio stones, but any other suggestions based on the pictures would be great! Thanks a lot!
    Kip
    [attachment=1:3gou9foh]DSC_0265.JPG[/attachment:3gou9foh][attachment=0:3gou9foh]DSC_0266.JPG[/attachment:3gou9foh]
    24 ft, 52" Patriot Vista AGP, steel wall, dished bottom, 14,300 gallons
    Hayward 1 hp pump, S180T sand filter, 2 - 2 X 20 solar heating panels, solar cover and reel, 8 gal Liquidator, TF100 test kit
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Re: under construction, first pics
    I din't know about that method would think it would was away over time on the outside of the wall unless your going to put some sort of retaining wall up.
    1988 Ceder Ridge
    24' Doughboy AGP
