Thread: What is the effect of low PH levels
    Hi
    I have an open air pool in Spain and though I have had it for four years know almost nothing about pools - other than how to clean them.
    The sand in my filter needs replacing, but I have put off doing it because I need to have some work done to replace tiles and a crack where the pool meets the patio.
    Last week the chorline levels were low, even though there are still some tablets in the dispenser. So I put extra chorline in the pool.
    This week the PH levels are very low. I will get some PH plus tomorrow, but in the meantime I would like to know what the effect is of low, or high, PH levels. I only have a simple test kit which shows four levels, it is on the lowest one.
    Montreal Canada
    326
    Re: What is the effect of low PH levels
    Putting aside the chemistry and water balance aspects, the low pH could possibly damage a liner by causing wrinkles, hardening and elongation. This is partly due to the acid dissolving the calcium carbonate used as a filler in PVC formulations. Elongation then allows the disinfectant to further penetrate the membrane possibly leading to discoloration.
