Thread: Hayward Dual Speed 1.5 hp sp2610x152s question
    Near Nashville TN
    50
    Hi to all- I finally have walls around my 20x40 Grecian Lazy L 8' rock hole! Getting closer everyday!! My question is how to wire the pump- no instructions- Also, I want to use a timer. I am new to this forum, and hope to use it a lot! thanks for your help.
    I also will hooking up an AUTOPILOT SWG, and I believe I need some optional piece to work with the dual spd pump- help there would be appreciated as well!
    Thanks
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    22,544
    Re: Hayward Dual Speed 1.5 hp sp2610x152s question
    Is there a data label on the pump? That's you best bet on how to wire the pump. Pump mfgs use different model motors during production runs so it's hard to give a standard wiring diagram based on pump model.
