Thread: Chlorine burn rate
    Cary, IL
    29
    Chlorine burn rate
    I recently had to shock and once my FC stabilized, I was at 20ppm FC. I was hoping to be able to go swimming the next day but not at 20ppm. So I opened up the cover and let the hot sun shine down on the pool all day and by the end of the day, I was at 4ppm. I was amazed at how just 8 hrs of sunlight brought it down that fast however I was also concerned that maybe it wasn't just the sun and that maybe I still had a issue even though my FC had stabilized the night before. But sure enough, the next morning, I tested again and found 4ppm FC. So my question is, does FC burn off in sunlight at a higher rate in higher concentrations and then slow down once it reaches a certain ppm level? I don't ever recall losing that much FC during the day even with kids in the pool. My CYA is 55. Just curious how so much burned off so fast when I know I have stabilized FC overnight.
    Bill Boehm
    Cary, IL
    40,000 Gal, 20x40 IG Liner with water slide and swim out. Auto-cover, Polaris 280, Pentair (Sta-Rite) VS-3050 pump with EasyTouch Control System and Laars LG250N Heater.
    Re: Chlorine burn rate
    The amount of chlorine you use up is a percentage of your starting level. So if FC starts high, you lose more than if chlorine starts low. With CYA around 55, you should lose perhaps a little less than half of your chlorine over the course of a sunny day. You lost quite a bit more than half, so I suspect that you had something else that was using up chlorine.
