Results 1 to 9 of 9
Thread: filter shooting bubbles
    Jun 2010
    Dayton, Ohio
    241
    my pool is shooting bubbles. this is a new development. no obvious problems. what should I be looking for?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: filter shooting bubbles
    If you had a SWCG, I'd suspect that's it.
    Are there bubbles in the pump while running? i.e. - a suction side air leak
    Luv& Luk
    -Ted
    Jun 2010
    Dayton, Ohio
    241
    there is a tiny crack in the pipe that connects the skimmer hose to the basket that attatches to the motor. I am guessing that may be it? would that be right? I know I am not using right terminology....
    22,553
    I'd bet that crack is your issue. Any crack or leak in the suction line (skimmer to pump) will suck air into the system.
    Jun 2010
    Dayton, Ohio
    241
    I replaced the part that was cracked....thought I would be home free when I saw the basket fill with water and no air at all. But low and behold the return was still shooting bubbles. I took apart everything. all fittings checked o rings did all the tips and hints to find out where air is getting in. put it all back together and still have bubbles. less bubbles but bubbles. I am not sure what to do next.
    22,553
    Is your skimmer weir operating freely or is your skimmer creating a vortex and sucking air in that way?
    Did you lube the o-ring on the pump strainer basket lid?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,421
    Also bleed the air out of the filter.
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    Dayton, Ohio
    241
    there is no vortex. I bled the pressure out of the filter. I did not lube the o ring. I will try that.
    Jun 2010
    Dayton, Ohio
    241
    This post is three years old and I still have bubbles! Lots of them and I never did figure it out.
