Thread: How to install the sand filter,gas heater and pump on an AGP
    We are in the process of setting up an used oval 18x12 AGP.Walls are up,liner is next, but we would like to see pictures of gas heater,filter and pump,
    installed,to get everything connected.
    Thanks for all the info and the pool school for us ,beginners
    48,000 Gallon gunite pool
    Cartridge filter. 2HP pump
    Runs 12 hours/day
    South Central NJ
    3,192
    Re: How to install the sand filter,gas heater and pump on an AGP
    Skimmer to the front of the pump. Pump discharge to filter in. Filter out to heater in. Heater out to pool return. Use pressure rated pvc pipe and schedule 40 fittings.
    Scott
    Owner of - PoolGuyNJ LLC
    Thank you Scott.That's what we were looking for
    Runs 12 hours/day
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Make sure to put valves in line on both the skimmer and return. I would also use unions
    ( http://www.flexpvc.com/cart/agora.cgi?c ... PVC-Unions )
    between pool and equipment.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Thanks for your advice
    Runs 12 hours/day
