Results 1 to 10 of 10
Thread: Final pics I never got posted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I finally got some grass and rock around my pool so I thought I would share a few pics of the finished product. Also had a building built around my equipment.
    Thanks TFP. I could have neve done it without you guys and gals
    Just thought I would throw in the rainbow for the heck of it
    Pool is in the back yard. Porch you see is on the side of the house facing east.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Jan 2008
    Northeast Florida
    161
    Re: Final pics I never got posted
    Beautiful! What a landscape (and the pool is noce too!)
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    skydiva44's Avatar
    Houston, Texas
    200
    Wow! It's awesome...I would never leave that spot all summer with that view.....
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Wow. That is just amazing!
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful
    You're done SLAMing when:
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Beautiful. Quiet. Peaceful. Secluded. Perfect.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks everyone. It is very peaceful. Very hard to go to work everyday. I'm not doing anymore landscaping. I figure my landscaping came with the farm
    Lynn
    Feb 2009
    West Virginia
    216
    Very nice!
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    Oct 2010
    Kansas City, MO
    14
    Very, very nice! What a view.
    Shores
    17,000 Gallon Vinyl-lined In-ground Sports Pool
    Triton II Sand Filter; WhisperFlo Pump
    Pentair Intellichlor Electronic Chlorine Generator Model IC40
    Ray-Pak Gas-Fired 250,000 BTU Pool Heater
    Polaris 380 Automatic Pool Cleaner with Booster Pump
    EasyTouch Control Panel
    Save-T 3 Automatic Pool Cover
    3 Skimmers, 3 Inlets, No Main Drains
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    A full on rainbow! WHAT DOES IT MEAN???!!!
    [youtube:13e80ezu]OQSNhk5ICTI[/youtube:13e80ezu]
