Results 1 to 14 of 14
Thread: TF-100 test kit
    Jun 2010
    Piketon, OH
    17
    TF-100 test kit
    Just got my kit and tried to test for chlorine level. I added the r-0870 and nothing happened, no pink just clear. I used the speedstir to mix and still nothing. Tried another scoop and still clear. Any suggestions or is my chlorine level just to low to register?
    30,000 Gallon IG pool, vinyl, Aqua-rite T-cell 15 SWG, 1 1/2 HP with Tagelus TA60D sand filter 60 gpm
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    I also tried to test for CYA and not sure I performed correctly. The black dot never disappeared. Was the solution supposed to be clear or colored? We just moved in to the house, the water is clear but looks dirty or algae on bottom of deep end. The only thing I have done so far is added salt to get up to 3200ppm.
    Guest
    Re: TF-100 test kit
    Based on your description, you have no FC and no CYA. Post a full set of values so we can put you in the right direction!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: TF-100 test kit
    Test the chlorine using the color matching block. If it stays clear, you got no chlorine. Better get some in there fast.
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    My pH looked to be around 8.4
    and my TA was 140
    my question is should I use Trichlor since it raises FC and adds CYA while lowering pH (according to pool calculator)?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: TF-100 test kit
    Dichlor would be a better choice than trichlor - trichlor usually is found in tablet form which won't raise the CYA quick enough.
    The cheapest method is to buy stabilizer seperately, and use liquid chlorine/bleach to shock the pool. I'd recommend this method for your situation.
    Before you begin to shock, use Muratic Acid to lower the PH down to 7.2.
    Have you tried using the Pool Calculator yet?
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    Do they sell stabilizer at walmart? or do I need to go to pool store?
    I have some muratic acid, so start there right?
    How long before the kids can swim?
    My full results this am
    fc 0
    cc 0
    tc 0
    pH 8.2
    T/A 140
    CH 420
    CYA 0
    Thanks again. I feel like such a pool idiot!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: TF-100 test kit
    It might be a few days before the kids can swim. Welcome to TFP.
    Yes start with MA and lower to 7.2. You can find HTH or any oher brand stbilizer/conditioner (aka CYA) at walmart or your local HW store. Use the pool calculator to figure out how much you need to add.
    It sounds like you will need to shock and you want to aim for 30ppm CYA (70-80 is usually recommended for swgs, but it is easier to shock at 30 and you can raise it later ). Get some regular 6% bleach in there now to at least 3ppm, then after you add the CYA raise it up to roughly 12-15 ppm and hold it there. With no CYA your SWG can not keep up with chlorine demand, and with FC at 0 looks likes you have already started to see an alage outbreak. Just use liquid chlorine for the next few days, turn off the swg. Once you are done shocking, you can raise your CYA to the recommended SWG level and continue using your SWG.
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    Thanks
    How long after i add the bleach before safe to swim?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: TF-100 test kit
    Quote Originally Posted by brbbbfuller
    Thanks
    We do not recommend swimming while shocking.
    You're done SLAMing when:
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    I added 2 gallons of bleach to get FC to 3, 120 oz of muriatic acid to get pH to 7.2, and 4 pounds of stabilizer for CYA levels. I need to add another 4 pounds-should I wait until the other is dissolved to add the remaining 4 pounds? How soon should I test? tonight or in the morning?
    Thanks so much!
    Richard320's Avatar
    Jan 2010
    18,995
    Re: TF-100 test kit
    Thanks so much!
    FC and pH can be tested an hour or so after they were added, assuming the pump's on and things are circulating. Are you doing an overnight drop test? Shocking? (Kinda doubt that, 3 isn't very high) If neither applies, check it in the morning sometime.
    The CYA was powder, since you refer to pounds not fluid ounces, so it will take a week or so to completely dissolve. Save your reagent and give it a week before retesting that. You can add more any time, getting rid of excess CYA is a pain, having excess CYA is a bigger pain.
    Jun 2010
    Piketon, OH
    17
    Re: TF-100 test kit
    New test this am
    fc 0
    cc 0
    tc 0
    pH 7.5
    t/a 100
    ch 360
    cya not tested since just added last night
    so just keep adding bleach to get my fc levels up? Should I go to shock level now?
    Did my fc level not go up because of the live organisms in the pool or walmart brand bleach?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: TF-100 test kit
    Yes, go to shock level and hold it there. Calculate shock level based on how much CYA you added. Assume the amount of CYA added is active in the water.
    Organisms in the pool will consume FC quickly until they are removed, that is why the FC is not holding yet. Bleach from Walmart is fine as long as the chlorine is 6%. Since they have a high volume of shoppers you are more likely to get fresh bleach there than at some other places.
    Once you get to shock level, test every couple of hours and add chlorine as needed to stay at shock level until you pass the overnight test. (you lose 1ppm or less of FC from dusk to dawn and your CC is .5 or less) Turn off the SWG while you are doing the overnight test. Once you are finished shocking, use liquid chlorine to raise the FC to regular level and then set the SWG to keep the FC stable.
    Love TFP? Become a
    TFP Supporter!
