Thread: Chlorine levels, pH and CYA...a few q's
    Hello all,
    New salt water pool owner.
    Things have been going well, but a few q's as i get more into this:
    1) Our Poolpilot Digital is set to 25% now, yet our FC levels are in the 8.0 - 8.5 range. Seems high given the fact that it is on 25%. I did notice the power level is set to 2 and not 1. Should I adjust?
    2) Our CYA seems to be at about 60. Assume I should probably bring this up a bit (to 80) but with the high FC i wasnt sure.
    3) My target pH is 7.6, Seems like I need to add about 20-30oz of acid/day to keep it there. I've typically just used the cheapie pentair kit. Today I tried the taylor kit in out TF-100 and it gave me a reading ~0.3 lower. Seems odd...any rationale?
    thanks!!
    Eric
    Re: Chlorine levels, pH and CYA...a few q's
    Is this a new pool with salt water or an old pool with new salt water system or an old pool with an old salt water system and a new owner?
    new pool, new owner....
    26,000 IG gunite
    Tonights #s:
    PH: 7.5
    TA: 100
    FC: 8.5
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Turn the setting down to 1, your CYA is fine. It's normal to have to use a lot of acid while the plaster cures. It will slow over time but you can expect the ph to drift up for a full year.
    I would trust the taylor kit over any other.
