Thread: Filter Pressure question
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Some PB say a pressure of 10# is normal but our PB says 22# is normal.
    Why the diff?
    Thanks to this board I am now questioning my PB recommendations, and of course the PSS.
    Thanks in advance.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Re: Filter Pressure question
    Every pool is different. 10 psi is normal for some pools, 22 psi is normal for other pools. Anything from about 2 psi up to 30 psi might be normal. It depends on the size of the pump and the resistance to flow of the plumbing system.
    All that really matters is knowing what pressure is normal for your pool by watching to see what the pressure is with a just cleaned filter.
