Results 1 to 9 of 9
Thread: Higher FC then normal, kids eyes red and burning....
    Aug 2009
    Kodak (East), TN
    20
    Hello, I am having a pool party tomorrown and want to be sure that the water is ok, and comfortable for people to swim in. Here are my numbers:
    FC-10.5
    CC-.5
    TC-11
    pH-7.6
    T/A-160
    CH-260
    CYA-70
    Salt-2820
    Have been running the SWG for 12hours at night. And in the last two nights the temp has gone down a bit (from about 75 down to 65).
    I normally average a FC of about 4-5. From what I can tell from Pool School, a FC of 10.5 is ok to swim, but my kids eyes are burning after swimming for a bit. This is not usual of a SWG run pool...correct??
    Is there anything I need to do to adjust my numbers? And is there any other way then just running the SWG for less...to lower FC a little bit? And should I just leave the SWG completely off tonight??
    Thanks so much!!
    Pool-Mom
    AG, 13500gal, 24x52 Intex Metal Frame, Krystal Clear Filter Pump Model 633, with Intex SWG
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Re: Higher FC then normal, kids eyes red and burning....
    Not to discount any issues with the water chemistry, but have you changed sunscreens/blocks recently for the kids. We had a similar problem awhile back and determined that was the problem. Switched back to the original one, and no problem.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,629
    Numbers look ok to me. My daughter has been complaining when my FC is at 8 and all other numbers are good. Maybe she's just sensitive.
    30,426
    The numbers are fine to swim but with your SWG, I don't see any reason to run your FC that high. 3-5ppm should be fine.
    (Man, that water's cold....you must be in the mountains)
    There is a small chance that this is related to your CC level. CC can cause those symptoms. Normally CC isn't a problem at 0.5, but once in a long while it can be just above 0.5 and still test as 0.5 and be a problem. When you do the FC/CC test and get to the CC step, is the water a clear obvious pink, or is it an extremely faint pink?
    Aug 2009
    Kodak (East), TN
    20
    Ok...to answer all the questions:
    I haven't changed the kids sunblock lately.
    I do live in the mountains...LOL. But I meant the the temp outside went from being 75 at night to 65. I don't have a thermometer for the pool water, but I assume after a few nights of cooler outside temp, the water temp would drop a little too.
    And when I did the CC test, the water was a very faint pink. And when you say "problem", what can I do to remedy this problem (if there is one)??
    Thanks again everyone!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Try lowering PH to 7.4...not sure why, but it seems much more comfortable on my eyes...then again, maybe it is just in my head
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by dmanb2b
    It is because that is the optimum pH for the human body. A normal bloodstream pH is between 7.35 and 7.45. 7.4 is right in the middle perfect.
    Mar 2007
    San Rafael, CA USA
    12,082
    The pH of human tears varies, but as described in this link (or this link which is the same thing), it averages around 7.5.
    For me, my eyes only burn when my sunscreen gets into them, but man does that sting.
    Some eyes can be sensitive and when we say "safe to swim in" up to shock level that doesn't mean you aren't going to notice the higher active chlorine level. As Dave said, you can have your FC in the 3-5 ppm range (for your CYA of 70 ppm) which should be less irritating, though I suspect it's not the chlorine level since eye irritation usually requires far higher chlorine levels -- for chlorine with no CYA in tests on rabbits' conjuctiva, reactions start at 16 ppm. Reaction with monochloramine starts at 3 ppm. If you retest your CC level using a 25 ml sample size, I suspect it may be <= 0.2 ppm so is probably not the source of the problem.
