Thread: 1934 Popular Science - How to build a pool
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    http://www.popsci.com/archive-viewer?id ... mming+pool
    "One does not need to be rich to enjoy a private swimming pool. The materials for a small pool can be obtained for less than $100 ....."
    I love this article from 1934 about how to build you own swimming pool.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Feb 2008
    Denton, TX
    5,061
    Re: 1934 Popular Science - How to build a pool
    That's really awesome!
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    What I like most about this is the assumptions made about the capabilities and "handiness" of the readers. No consumer magazine - especially a mass-market one - today would even attempt such a thing, as they know most consumers wouldn't have a CLUE as to lumber grades, concrete ratios and the like, much less be interested in the actual hard work to do such a thing. I love the estimate that with an "assistant or a strong boy" any man can do this. Not 80 years later, that's for sure.
    It is interesting that they are so relatively cavalier about sanitation (both disinfection and mechanical filtration). A variety of technologies (including sand and DE filtration, and multiple different kinds of disinfection) were well-entrenched by the 1930s, as were technologies such as underwater lights (not necessarily safe ones), all manner of skimming ledges (often called "scum gutters") and the like. I actually wrote a Master's these on those developments years ago.... I guess, in fairness to Popular Science, they were looking to keep it "simple" for the homeowner.
    An amazing little time capsule.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    I like the "method of sterilizing water"..."muslin or cloth bag containing 1 lb of Bluestone (copper sulphate crystals)" tied to the end of a stick..."swish around each morning until the water turns light blue" Cool.
    Vintage 1963 20' x 40' elliptical, 27,000 gal. painted concrete, diving board, Sta-Rite Dura-Glas pump DIY upgrade 2009 with A.O. Smith B2981 E-Plus New Centurion High Efficiency Two-Speed Motor, full rated-1.67 SF 115V, 3/4 hp-12.4 amps high speed, 0.10 hp-2.2 amps low speed running 24/7 low speed, Hayward 225T sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I Think that sounds about right, $100 from 1934 inflation adjusted comes out as about $1,500 today, it sounds like they were doing a fair amount of scrounging to get there and assuming free labor. If you assume about a 50% savings thanks to the scrounging factor, that will bring the budget up to around $2,250. The example pool appears to be 28 ft long and about 12 feet wide, with a 6'6" deep end and about a 3'6" ft shallow end (to the rim) being built as partly above and partly below ground. I can see this being within the realm of physical work a pair of men in fair condition could do in their spare time over the course of a few weeks. Consider a modern above ground 33x18 foot oblong 52 inch deep above ground pool complete with filter and pump can by bought from Sam's club for under $2,000 and set up for far less labor. As to the labor my 20x40 foot pool was dug by hand 30 years ago, more importantly it was dug by hand by a crew of teen age boys in 2 days, plus another 2 days to form up the sides and add the liner, plumbing, set in the ladders and diving board, and pour the deck. From marking ground to swimming in the course of under a week, with the oldest person on site for most of the construction a 20 year old college student (who happened to also be a neighbor) (the adult contractor supervisor was also supervising the construction of 3 other pools that week so would drive back and forth between them as issues came up). These were the same boys that would work picking water melons, or stacking hay, they would often be high school football players who wanted to stay in shape over the summer break and make a few extra dollars. These days these type same kids requires summer camps with professional exercise equipment to stay in shape, I can tell you from experience picking 30-40 pound water melons and loading them on a trailer being pulled across a field at a fixed speed behind a tractor can provide anyone with enough exercise. You get all the right incentives, you get paid per melon picked, pay for the ones you break, you get to run across a field with obstacles/tripping hazards (vines, snakes, etc) you have performance goal set by the guy driving the tractor, if you don't keep up you don't get paid. You learn team work, pickers toss to loaders, and they rotate jobs to stay fresh. Oh and of course the best part is there is always a chance to eat water melon at the end of the day, because some always break.
    Ike
