Thread: stained poolbottom
    Jul 2007
    Michigan,
    18
    stained poolbottom
    Hi, I've seen the posts with the chlorine tab on top of the stain (and it works)but what about my bottom that is quite more than a spot it's in all the vinyl creases and some round the edge.
    I have been keeping it well topped up with bleach and although my ph is a bit high (8)the water is crystal clear, I will be ordering the test kit asap but is that really a factor in creating the stains.
    Please advice !!
    Regards David
    14500 gl, oval, vinyl
    Feb 2008
    Denton, TX
    5,061
    Re: stained poolbottom
    Do you have any test results that you can share with us?
    So you are saying that placing a chlorine tablet on the stain actually lifts the stain?
    Jul 2007
    Michigan,
    18
    yes it lifts the stain no results sorry just keeping it well topped up with bleach till i get the test kit
    Feb 2008
    Denton, TX
    5,061
    Running a high FC should fix the stain eventually then.
