Thread: Inlet- outlet confusion
    Hello everyone, I tried to post this but guess it didn't take.
    I am new to posting and to pools. This site is pretty neat and sure glad I found it.
    I am wanting to know if I have this popup pool filtering wrong.
    Is the water that comes back in to the pool supposed to be closer to the surface of the water than the strainer/ suction side?
    Mine is the opposite, does it make a difference to the pump or the circulation of the pool?
    In other words, my suction line is at the top surface and the clean water comes in about 4 inches under the water level
    TYIA
    AGP, POPUP, 3800GAL. SWG 2000 GPH pump. Over the wall skimmer. SE TX. NEWBIE
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Inlet- outlet confusion
    That should be correct. On the standard pools our skimmer is at the surface and return is lower
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Quote Originally Posted by NWMNMom
    Thank you so much NWMNMom.
    I had almost had DH drain part of the pool to switch it, because I thought I had put it together wrong. Thanks again.
