Results 1 to 9 of 9
Thread: Polyquat 60 for Intex pool
    Jun 2007
    MA
    165
    I seen in the pool school to use Polyquat 60 weekly, Iv'e seen hth algea stuff at Walmart in a gallon sized jug is this the same stuff? Looks like shipping is a killer for chemicals.
    Cheryl
    14X42 Intex Ultra Frame
    Feb 2008
    Denton, TX
    5,061
    Re: Polyquat 60 for Intex pool
    If the ingredients have the term "poly" in it, it should be polyquat 60. Polyquat is typically more expensive than the linear quat stuff. It also doesn't foam like the linear quats do.
    As for the HTH stuff, it wouldn't surprise me if it was copper-based.
    Jun 2007
    MA
    165
    Any idea if walmart/target carrie it? I only have a Namco around me I can't stand them. If I have algea I want to start working on it tomorrow and not wait for something to ship.
    Cheryl
    Feb 2008
    Denton, TX
    5,061
    Well, if you have algae, then you don't need an algaecide. You just need to shock your pool.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    The Walmart stuff is ammonia based - not polyquat. I did see polyquat at Kmart one time - surprise and shocked, pleased too - I bought up all three quart bottles. Now they stock the same as Walmart. I only use polyquat at closing to prevent algae while the winter cover is on. For swimming season algae, nothing beats chlorine - Bleach
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2007
    MA
    165
    Pool school tells me for an intex pool to use it weekly.
    Cheryl
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We had an Intex for many years and only used it right at start up in case there was some lingering algae from closing and storing. I used only BBB for regular maintenance - perhaps they suggest it if there is an underpowered pump and filter connected to the pool?
    Aug 2009
    Close to Houston
    25
    Sign up for Leslies emails and every so often they will send half off coupons on the poly 60 and other things also, not just chemicals either. That's if you insist on using it.
    18' above ground from Leslies
    Hayward sand filter (100 lbs) with 50 lbs Zeosand
    1 HP pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The Poly 60 suggestion assumes the reader is new to pool ownership and provides some algae "insurance" in case you do not have a good test kit or get lazy maintaining you water. If you keep your water balanced daily, it's not needed.
