Results 1 to 11 of 11
Thread: Phosphates?
    May 2008
    florida
    112
    Phosphates?
    I went to the pool store to get my water tested and he said that it is high in phosphates. I have owned a pool for 20 years and never heard of this. He said it is from the rain water. He said it is at 300. He said that I needed to add a bottle of Phos Free. I usually use Pool Doctor but went to Leslie's because I needed chlorine and they are closer.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Phosphates?
    You dont need to wory about phosphates at all. They are irrelevant in a properly chlorinated pool.
    How do you chlorinate? Do you have your own test kit? Did Leslies test the water? What were the results?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Phosphates?
    Ignore them.
    Phosphates are food for algae. Wood is food for a fire. If you don't have a fire, it just sits there, same as your phosphates in the absence of algae.
    May 2008
    florida
    112
    Re: Phosphates?
    Thanks. Leslie's tested and gave me this:
    FC 5+
    PH 7.6
    TA 120
    CH 250
    CYA 60 (just added on Sunday)
    TDS 1800
    Phosphates 300
    I have IG that is chlorinated with chlorine. Have a cartridge. It is 17,000 gallons.
    Dec 2009
    2,690
    Re: Phosphates?
    I meant how do you add your chlorine? Liquid, powder, or pucks?
    May 2008
    florida
    112
    Re: Phosphates?
    Sorry, I thought I said that. I use liquid chlorine. Only use pucks when I go on vacation.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Phosphates?
    Excellent analogy.
    Mar 2011
    Houston, Texas
    413
    Re: Phosphates?
    I just had my water tested at my local pool supply store and they said my phosphates are at 2500 ppb. They recommend--for about $75--the commercial grade of Phosfree. The phosphate level was 100 ppb about 5 weeks ago and the jump is due to the enormous pollen drop we get in Houston this time of year. Pretty much everything outdoors is covered in a yellow dust. Every few days there is a yellow line on the tile in my pool. It's finally starting to subside.
    My numbers are as follows:
    FC 7.0 (just started my SWG so it's a little higher than normal)
    CC 0.0
    pH 7.5
    TA 80
    CYA 80
    Hardness 355
    Salt 3500
    I take it that even at 2,500 ppb, I should not worry about phosphates. Correct?
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Guest
    Re: Phosphates?
    Quote Originally Posted by HouTex
    CC 0.0
    pH 7.5
    TA 80
    CYA 80
    Hardness 355
    Salt 3500
    You are correct
    Mar 2011
    Houston, Texas
    413
    Re: Phosphates?
    Thanks. This forum is a great resource. Lot's of good information here.
    Re: Phosphates?
    Discussion of maxepr1's comments has been moved to this topic.
