Thread: Brown spots
    Brown spots
    I have a 24' round above ground pool, vinyl liner. I have a bunch of brown spots on the floor of the pool. What causes them and can they be removed?
    I assume they don't brush off. There are a number of possibilities. One way to narrow down what might be going on is to make two tests. Get a few Vitamin C tablets and crush them and put the powder in a sock. Rub the sock gently on the stains and see what happens. Also, get a trichlor tablet and rub it gently on the stain and see what happens.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Demi,
    Please post only in one location. I promise plenty of people will join in the discussion. Welcome to TFP.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    brown spots
    sorry about the extra posts - i am new to this and didn't realize that I did that.
    What does the Vitamin C tablets do? Trichlor tablets - are those the chlorine sticks? I have chlorine sticks do I rub one on the stain?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Vitamin C will lighten or remove the stain if the stain is metallic. The chlorine will remove it if the stain is organic. I just put a vitamin C tablet on the spot and leave it overnight.
