Results 1 to 8 of 8
Thread: Has this ever happen to you?
    Jun 2010
    Washington, DC
    56
    Last night as I was getting ready to test for FC and CC (I have the TF-100), I placed a heaping scoop of R-0870 using the tiny blue spoon to my 10ml pool water, the water didn't turn pink. It stayed clear. I thought there is something wrong because I tested a few hours before and it was above shock level and I have only been losing like 2 - 5 ppm at the most. I decided to toss that water and started again and this time the water turned pink. I used the same water from my measuring cup.
    What happened there?
    Pool size = 24,000 gal.; rectangular 3 ft shallow, 8 ft deep
    Jacuzzi Sand Filter (can't find the model) flow rate 60, Pentair Super Flo, 1HP
    Pool is inground/indoor and white plaster, TF-100 Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Has this ever happen to you?
    If you know there is chlorine in the water and it doesn't turn pink, add more powder.
    30,402
    It sounds like your FC was pretty high. If that's the case, sometimes one scoop is not enough to turn the solution pink/red. It typically will "flash" pink and then go to clear.
    The solution is to add another scoop of DPD powder.
    (John beat me but I love to see my words in print!!! )
    Jun 2010
    Washington, DC
    56
    Oh I see. Thanks for the clarification. Awesome test kit btw, .
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Funny Dave.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Jun 2010
    Washington, DC
    56
    I have another question. I normally throw away my test water right after testing so I haven't noticed. Tonight in my haste to get stuff done i somehow started brushing the pool without cleaning up. When I was putting things away I noticed that the water in the vial turned back to pink. Is this normal?
    Yes, completely normal.
    Jun 2010
    Washington, DC
    56
    Thanks.
