Thread: Swimquip Niche
    Mar 2009
    Arizona
    2
    Swimquip Niche
    Does anyone know if there is an LED bulb or compete light kit that will fit into an old swimquip niche? I have been looking around and it seems like my only option is the standard 500 watt bulb and a colored lens kit. Any info would be greatly appreciated.
    Bushdoc
    30 X 15 In Ground Concrete
    600 Gallon Hot Spring Tub
    Blue Diamond RC Robot
    BBB All the Way
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Swimquip Niche
    Sorry, can't help....
    Jul 2008
    Flintstone, GA USA
    112
    Re: Swimquip Niche
    Yes, there is a pure white LED bulb that will fit perfectly and replace the edison type bulb. It is made by J&J electronics. I have been talking with them about this and have not ordered it though because I want a color changing LED bulb that will fit the old swimquip niche. Jack with their sales told me last fall that they were coming out with the white light in January of this year and the colored one would be out sometime later. So far the colored one is not out yet .
    Contact them. You can find them by googling J&J Electronics or J and J Electronics.
    Hope this helps.
    Several pool suppliers still carry the light kit for the old SwimQuip niche but not the bulb. You can get it by contacting J&J.
    I have not been able to find the lense kit that SwimQuip use to have. No one has it. I found one but the supplier said they did not know if the lense kit would fit the original SwimQuip light.
    A pool contractor sold me the Hayward Color Logic light and said it would fit hte SwimQuip niche but it would not and he will not give me my money back. Sorry contractors, I have had 4 of them so far since last fall working on remodeling pool and deck for a cost of approx 32,000.00 and had to fire all of them. I have hired the 5th one and so far he has done what he said he would.
    Please let me know your results.
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    May 2011
    Orange County, CA
    696
    Re: Swimquip Niche
    What about this:
    http://www.poolsupplyworld.com/homepage ... QgodNho60Q
    There are several other options for this kind of bulb on eBay.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Jul 2008
    Flintstone, GA USA
    112
    Re: Swimquip Niche
    Quote Originally Posted by CraigMW
    What about this:
    The color logic light you referenced http://www.poolsupplyworld.com will not fit in the SwimQuip niche. The only option available at present is the pure white led bulb that I told you about from J&J Electronice which will replace perfectly the Edison type 500 watt bulb that came with the light originally. If you want the color changing led bulb that will replace the original edison type bulb then you have to wait until J&J Electronics comes out with it. I have not been able to find out at this point when this will be. When they do all you have to do is order it and take the lense off your light and screw out the edison 500 watt white bulb and screw in the led color chaning one then replace the original gasket with a new on that J&J makes and install the light back into the niche. There is no other color led bulb that will fit the SwimQuip niche.
    Tom
    Tom
    Jun 2008
    Cleburne, TX
    7
    Re: Swimquip Niche
    The year is now 2014 and I still can't find an LED color changing bulb that will fit my Swimquip housing. Considering using a smaller spa light that will fit in the housing and I know the light output will be less... has anyone tried using a spa light?
    15,000 gallon gunite pool
    7,000 gallon, in-ground, aggregate finish, screen-enclosed, Hayward CX-900 cartridge filter, 1 HP pump, Melbourne, Florida
